Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Jun 2013
    Posts
    2
    ashland city tennessee
    john deere 318
    Default 318 john deere
    just rebuilt a b 48 onan engine in the john deere but it wont run at all unless choke is closed off. ive tried replace filters lines surge pump everything but nothing seems to work. im going to recheck valve clearance any other ideas
  2. #2
    New Member sootman73's Avatar
    Join Date
    Jun 2013
    Posts
    10
    Delta, OH
    John Deere GT235
    Default
    sounds like you have a plugged jet or the wrong jetting in the carb. did you rebuild the carb and replace the jets including pilot jet(used at idle)?
    1999 John Deere GT235 18hp Briggs v-twin
    48c deck
    John Deere 10 wagon
  3. #3
    Gold Member
    Join Date
    May 2005
    Posts
    321
    Default
    Check to make sure your fuel pump is pumping. Check the crankcase vacuum to make sure your pulling enough vacuum to run the pump.
Similar Threads
  1. John Deere 318 Starter wiring issues
    By Bret Weymouth in forum John Deere Lawn & Garden
    Last Post: 06-24-2013, 10:57 AM
  2. John Deere 318 Starter Replacemet Issue
    Last Post: 06-12-2013, 11:57 PM
  3. hydrostatic lever adjustment JD 318
    By GTOJD in forum Parts/Repairs
    Last Post: 05-07-2013, 10:08 AM
  4. Just bought a JD 318, runs good, need to get maint. caught up
    By sallread in forum John Deere Lawn & Garden
    Last Post: 05-03-2013, 09:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
