Results 1 to 2 of 2
  1. #1
    Silver Member purpony's Avatar
    Join Date
    May 2006
    Posts
    141
    CT
    JD 2440/JD 3020/JD 314/JD 345/JD 850/JD 2320
    Default 345 hydro will only move half speed-
    My 345 hydro mower will only move half speed.... not sure where to start. Checked fluid level and thats fine. Should i do a filter and fluid change?
    1989 Mustang Twin Turbo, 6 speed - 610RWHP/682RWTQ
    2004 F-150 Lariat 4x4 Supercrew - Lifted on 35's
    1998 Lincoln Mark VIII (46K original miles)
    1998 Limited V8 Explorer (owned since new, 178K and climbing)
    1992 Ford Ranger XLT 4x4 - awaiting 302 swap
    JD 3020, JD 2440 with FEL, JD 314, JD 345, JD 850 Dozer, and a 2320 with 200CX FEL, 62D MMM, and Forks!
  2. #2
    Gold Member
    Join Date
    Jun 2013
    Posts
    287
    N. GA
    LX188/445/755
    Default Re: 345 hydro will only move half speed-
    Quote Originally Posted by purpony View Post
    I would look at the linkage underneath to see if something is loose or bent. Same problem for forward and reverse?
    I am not familiar with that mower but some have a brake interlock linkage that could be involved with the problem.
    Likely you will need to remove some sheet metal to see how all this works.
    The filter might be clogged but not if the problem started all at once.
Similar Threads
  1. Half speed with blower....help
    By Richard in forum Parts/Repairs
    Last Post: 04-21-2012, 09:34 PM
  2. Replies: 15
    Last Post: 03-22-2012, 08:33 PM
  3. KUBOTA travels at half speed
    By OCONNOR in forum Parts/Repairs
    Last Post: 02-21-2012, 09:44 AM
  4. 2 Speed Hydro vs 3 Speed EHydro
    By db05 in forum John Deere Owning/Operating
    Last Post: 04-22-2008, 04:53 PM
  5. Loader going up at half speed
    By albmn10 in forum Kioti Owning/Operating
    Last Post: 06-06-2005, 12:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
