My Dog ate my wiring chasing a mouse
   / My Dog ate my wiring chasing a mouse #1
Beechboy
Member
Greenwood BC Canada
2010 JD 3520,2008 JD LA 175, 1946 Ford 2N
Hello Friends,
I have a wiring issue on my JD LA175 Tractor.
Dog chewed some wires not sure of the correct routing and termination points.
The wire in question starts under the hood on the left side of the 26hp Briggs engine.
It is the red Wire with a disconnect at the engine on the module, I suspect that it then goes to the right side of the engine to a two place connector.
I think in the connector there is a small pigtail that also terminates at this two place connector but I want to verify before I connect it and energize
The circuit.
I will try to post a photo or two.
Thank -You !!
   / My Dog ate my wiring chasing a mouse #2
At least there are only a few wires to deal with. My brothers dog chewed up a wiring harness on the bottom of my F550 service truck when it was a month old, had to put 52 wires back together. I put them back together with uninsulated crimp connectors, soldered them all afterwards and used the heat shrink with built in sealant to cover the splices. That was nine years ago without any problems.
The crimp connections provide good mechanical connections and the solder aids in good electrical connections. Hope you can get this fixed up, others can help you more with the actual wire routing.
