OP
olgreyhair
Member
Thanks. I give it a try and report back. So you start it a min throttle and increase it I assume after it warms up a bit? G
Just an update. Tonight I went to start the 445. It cranked over a few times, tried to catch , and then just flooded itself out. I had to remove the plugs and dry them out. It then started right up, smoked a bunch to rid itself of the excess fuel and cleaned right out and ran fine. Very fustrating. I hate to do it but I think it needs a MAP sensor. Hard to test it if it works sometimes. Don't know what else would cause a flooding condition and then clean up.
I will check that before ordering a MAP sensor. When I turn the key you can hear the fuel pump run for a few seconds, the light on the dash goes out and it usually starts pretty fast. After it runs for say 15-30 seconds, it loads up, chokes, sputters, and usually clears itself. Runs fine after that. Twice now it has stated ran for just a few seconds and flooded out. At that point it will not restart until you pull the plugs and blow out the excess fuel in the cylinders. Then it will restart and run fine. What's happening is it's getting too big a dose of fuel at cold start. as soon as it starts to warm up, everthing works as it should. I'm thinking sensor or maybe fuel pressure regulator. Although I don't thing the regulator would go from being good and then bad.
Next to check the fuel pump hose piece in the tank I guess.
Any ideas would be helpful. Does a fuel pressure regulator ever stick closed and deliver too much pressure?
