flatheadfan
I have an older JD 318 318X113982 with a leaf collection system. it's old but I keep the filters and fluids up to snuff. I use it only 5 or 6 Saturdays a year to pick up leaves-then it goes into mothballs. It ran fine last Saturday for 3 hours and I put it back in the building. Today-all I get are dash lights and nothing else when I turn the key. No click in starter area. So far I have:
Checked battery and load tested it-battery is less than a year old and passed load test fine.
Replaced (2) 20 amp blade fuses on rail in front of hood latch catch. The originals looked OK
Cleaned terminals on ignition switch and reinstalled
Tested the neutral safety switch on the hydro lever and it is operating fine.
Disconnected the seat switch and bypassed it-still no starter engagement
I can flip up the PTO switch and hear it click.
The tractor looks like it had one of those hard start kits/box that mount on frame in front of starter area years ago-but I can't see where I have any current coming to that lead with a test light when I turn the starter to engage the starter.
I cant determine if I have a safety switch on the brake pedal-I think I remember having to push the pedal in to start-which i do with my other 318-but can't see a switch unless it's under the fender deck. Some forums say not all 318's have a safety switch on brake pedal. Lights work on dash switch when I turn it on
Anyone seen a ignition switch go bad especially in the mode where you turn it all the way on to engage the starter. Has anyone heard of one of those starter helper kits going bad. I'm trying to keep it simple. It ran like a champ for 4 Saturdays in a row-as it has for the last 5 years- and now is dead in the water
Any suggestions appreciated-especially where a safety switch would be for the brake pedal. Thanks for reading my post-I'll relay any info back that helps.
