Results 1 to 7 of 7
  1. #1
    Member
    Join Date
    Jul 2003
    Posts
    35
    Colchester, England, UK
    JD 4410
    Default 4410 battery dead/corrosion
    Hi - my 4410 is just about three years from new, has just over 150 hours on the clock and has been perfect until on Saturday it would not start. It has always been garaged.
    I couldn't get the battery out as the nuts had corroded - and there was quite a lot of white corrosion around the red terminal. I was able to check with a torch and there was water in each of the cells. I trickle charged it overnight and on Sunday same story -would not start.
    The dealer came out today and jump started it - so it was the battery that had died. He hacksawed off one of the nuts and took out the old battery, and connected a new JD one - which works fine. He is coming back to fit new bolts to secure the battery.
    I have read a few threads on this board about battery corrosion on 4310/4410 models and am a little worried
    There is some white material covering a couple of sqaure inches of the oil cooler - this looks like the stuff that was around the red terminal
    The other corrosion has brushed off fine.
    I am in the UK so not all the product options available in the US might be available here - I don't know what alternative batteries I might be able to get
    Question is - should I be worried? Is the battery leakage in on the oil cooler an issue,. and if so what should I do?
    Will this happen again - is it just something I have to accept every 150 huors or so?
    Should I ask the dealer to see whether John deere fancy paying the costs of the call out?
    Cheers Mike
  2. #2
    Elite Member DieselPower's Avatar
    Join Date
    Sep 2006
    Posts
    2,761
    Fairfield, PA
    JD 3020, JD 4230, JD 7410, JD 2440, MF 750, NH LS170
    Default Re: 4410 battery dead/corrosion
    For starters let me clear something up for the folks here in the US. When he mentions using a torch to check his fluid level he means a flashlight. So don't worry, he's not trying to blow himself up.
    My suggestion would be to get a sealed maintenance free battery that does not have "fill" caps. It sounds like if any battery acid leaks out it gets on the cooler. That's not a good thing since it will eventually eat through it and cause a leak. Most maintenance free batteries do have a small vent tube on them that vents gas produced in the charging cycle. You could simply place a small hose on this vent tube and route it down and away from the cooler thereby removing all posibility of getting acid on the cooler.
    Another thing you could probably do is get some battery mat. It's simply a mat that contains a acid neutralizing chemical. You could place a piece of this over the top of the battery and it would absorb any acid that leaks out. Anything to prevent it from getting on the cooler.
  3. #3
    Veteran Member jeffinsgf's Avatar
    Join Date
    Mar 2005
    Posts
    1,217
    Springfield, MO
    JD 4410
    My 4410 battery died after just 19 months of service, but luckily, it didn't leak at all. I was all set to go with an Optima, but my dealer replaced it under warranty. As long as they keep doing that, and it doesn't leak, I'll keep letting them.
    Is the "Optima" brand available in the UK? They are considered the premiere sealed battery here in the colonies - -- uh, States.
    Your local auto parts supplier should have an aerosol battery corrosion cleaner (spray on, let sit, hose off) and a spray on jelly that minimizes corrosion. If at the first of each month you check and fill the water and use these two products, you'll not likely see any more problems.
    4410 ePR, 3rd SCV, Skid Plates, TuffTop Canopy
    430 FEL, 48 BH, MX-5, Bush Hog Chipper, and more.
    455, 60" deck, MC-519, 3pt hitch
  4. #4
    Join Date
    Jul 2003
    Posts
    560
    Baldwinsville, NY (10 miles NW of Syracuse)
    JD 4310, ehydro, 4WD, R4s
    Mike,
    Same thing happened on my 4310. Thoroghly rinse and gently scrub the oil cooler, radiator, battery tray etc. with plenty of clean water. You want to remove any residual acid on the surfaces. Then recoat the area with paint.
    Jeff
  5. #5
    Join Date
    Oct 2006
    Posts
    63
    An old trick to keep the posts clean is to put a light coating of Vaseline on the posts. This prevents a build up of all kinds of stuff, some of which cannot be seen but which will prevent a battery from functioning properly.
  6. #6
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    Clean the area with 'baking soda' and water.
    (baking soda neutralizes battery acid)
    ::Sent from a standard desktop keyboard::
    My Photobucket
  7. #7
    Elite Member
    Join Date
    Dec 2001
    Posts
    3,133
    i read abot this issue on other forums and I inspect thhat area once or twice a month. If my battery croaks, I will get an Optima too.
    Nuru
    JD 3520
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
