448 BH woops (whine whimper)
   / 448 BH woops (whine whimper) #1
Cidertom
Gold Member
Benton Co Oregon
JD 4520, 2305 Aktive snow-trac ST4
Digging out the last tree root wad...
doing nothing extra, I was just digging and it came up out of the hole this way.
Had to finish hacking out the roots with the FEL.
Rod is $200, new cylinder is $500 ouch either way.
   / 448 BH woops (whine whimper) #2
Wow, any chance of the warranty covering that?
   / 448 BH woops (whine whimper) #3
Wow, that's unreal! Maybe that rod wasn't heat treated properly??!?
   / 448 BH woops (whine whimper) #4
I did the same thing, only mine snapped. Sounded like a .38 going off. Rod and piston rebuild kit = $300.
   / 448 BH woops (whine whimper) #5
Moan... groan.. That left a mark!
I can't help but wonder --- what psi is your hydraulic pump generating?
I'd like to believe that the pump would stall and whine before it would "spaghetti" the cylinder like that!
Most impressive ---
AKfish
   / 448 BH woops (whine whimper) #6
I've been around heavy equipment for 35 years and have never seen a cylinder bend like that. What where you doing???
I still don't know how it happened. I was digging out tree roots in preparation to pull over the last of the sequioa trees. I was about 6 feet below grade, had the bucket against the face then as I was lifting with the boom I tried to curl the bucket to finish the load. When the bucket came out of the hole it looked Ok untill I swung it to dump. Unless the relief valve failed I assume the PSI was around the 2500 factory setting.
I have used the bh a lot this last few weeks. But I am starting to wonder if I expect too much.. I tore up a bunch of teeth, now a cylinder.
I have seen a couple of FEl cylinders bent up by using the bucket as a ram, but never one on a bh.
Still, even with the cylinder and teeth, it stilll has been cheaper than the bid I got for pulling the trees out with a cat.
Anyone know who made JD's cylinders, or aftermarket replacements>
   / 448 BH woops (whine whimper) #8
In everything i have read. most backhoe relief valves are set a tad lower
than the tractor hydrolics. so say the tractor was 2500. the backhoe would be set at say 2300. from the looks of this. looks like a relief valve got stuck or something. as everyone has stated. This is most impressive. it just shows the power of a 448. maybe a little to much...:)
Chris...;)
   / 448 BH woops (whine whimper) #9
I did the same thing with a 46 BH while digging out a stump. It happened so quickly that I didn't really know what happened until I tried to curl the bucket and it stopped part way because the cylinder rod was hitting.
Phil
   / 448 BH woops (whine whimper) #10
Phil
Phil , I wish you had not said that. I have a 46 hoe.....:(
Chris..:)
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2018 FREIGHTLINER...
2017 MITSUBISHI OUTLANDER SPORT (A52472)
2017 MITSUBISHI...
SKID STEER HYDRAULIC TREE PULLER (A52472)
SKID STEER...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
BAUER ATD-750 VERTICAL HYDRAULIC PIPE HANDLER (A52472)
BAUER ATD-750...
