Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. #1
    Gold Member
    Join Date
    Mar 2003
    Posts
    267
    Western, NY
    Kubota B3200
    Default Feedback on Toothbar on 61" Bucket
    I have a 4310 with a 61" HD Bucket. I just purchased a JD toothbar for it and when I went to install it I found the fit to be way too tight. To the point it wouldn't fit. I got my grinding out and ground down the plate steel that bolts to the side of the bucket. I also ground down some welding burrs on the corners of the bucket. The plate steel is ~1/2" so taking a little off isn't such a big deal. Now the toothbar fits with a small gap (1/32" gap on both sides). My guess is that JD is marketing a toothbar that is for the skidsteers because the install instructions has there skidsteer models all over it. I did check the JD P/N and it was correct for my bucket plus I saw the toothbar mounted on a 61" bucket a few months before ordering. My concern is when I go to remove it how difficult it will be because of the small gap. Has anyone had to grind there toothbar to make it fit there HD bucket? I must say that this toothbar is very HD and a little overkill for my tractor. I think it weighs in at 120lbs. Works great though!!!
    Thanks
  2. #2
    Veteran Member nmu98's Avatar
    Join Date
    Jun 2007
    Posts
    1,130
    JD 5203, JD 3720, JD 4110, JD 445, IH 1586, IH 886, IH 404......
    Default Re: Feedback on Toothbar on 61" Bucket
    I am looking for one of those. Do you have the part number and the cost of it? maybe a picture?
  3. #3
    Gold Member
    Join Date
    Mar 2003
    Posts
    267
    Western, NY
    Kubota B3200
    The toothbar P/N for a 61" HD bucket is BW15227, weighs 136lbs and cost $313.
    Doug
  4. #4
    Gold Member Champy's Avatar
    Join Date
    Sep 2006
    Posts
    429
    Indiana
    John Deere 990
    I have the same setup on my HD 61" bucket, and it was tighter than a welldiggers #**. I have not ground mine down, but in order to remove it for winter plowing, I had to raise the bucket up and angle it downward...then applying liberal amounts of a handsledge got the toothbar to drop off (watch your toes). It's actually easier to take off than to put back on.
    Attached Images Attached Images
    A life spent making mistakes is more honorable and useful than a life spent doing nothing.
    4BusyDads
  5. #5
    Gold Member
    Join Date
    Mar 2003
    Posts
    267
    Western, NY
    Kubota B3200
    Yep, that's the same one I have. During the install I had to dry fit it a couple times before I drilled the holes. I did also raise the bucket and toggled the joystick and it "fell" right out.
  6. #6
    Platinum Member Chris2520's Avatar
    Join Date
    Mar 2007
    Posts
    779
    Marietta GA.
    I haft to pry mine off with a crow bar......
    its to tight. i am going to grind it down on the sides too...
    John Deere 2520 , R4's , 200CX loader with 61 inch bucket and JD Tooth Bar. And Markham 7 tooth. Tooth bar. 46 Backhoe with 16 inch bucket. with Custom made Street Flip pads off a 448 hoe. Foward work lights. Dual rear work lights. Heavy duty Alternator. I-Match , Ballast Box , Frontier BB2060 box blade , Frontier pallet Forks , JD 3 point reciever hitch. and soon A lot more.. and for grass cutting , John Deere GX 255 with 48 inch deck.
  7. #7
    Gold Member Mech's Avatar
    Join Date
    Jan 2007
    Posts
    409
    Pine, CO
    3520 CAB
    Quote Originally Posted by Champy
    I have the same bucket, with a bolt on cutting edge, on my 790 and am thinking about this tooth bar. Did your bucket have a bolt on cutting edge and you removed it?
  8. #8
    Veteran Member RollTideRam's Avatar
    Join Date
    Sep 2003
    Posts
    1,270
    Hartselle, Alabama
    Deere 3320
    I have the 61" HD bucket. It has holes all the way across the cutting edge. I figured these were for a bolt on cutting edge. I'm guessing you could pull off your cutting edge and install the toothbar. JC
    JD 3320, KK rake and tiller. Millonzi grapple, pallet forks, tooth bar. Deere Z930R
    01 Ram 4x4 2500 CTD and 22' 12k trailer, Big Tex 7x14 dump trailer.
    2015 Polaris Ranger 570 F/S eps
  9. #9
    Join Date
    Jan 2007
    Posts
    409
    Pine, CO
    3520 CAB
    My cutting edge is held on with 10 bolts. The bucket seems to have an edge but it isn't very sharp.
  10. #10
    Gold Member
    Join Date
    Feb 2008
    Posts
    262
    Quote Originally Posted by RollTideRam
    HD buckets use bolt on cutting edges. Shouldnt he have gotten one with the bucket, or are they a seperate part you have to buy?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
