Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Jul 2007
    Posts
    18
    Northcentral Pa.
    JD 2305
    Default 260 Backhoe
    I'm a "noobie" here on the site but I've been "lurking" for some time. I have a 2305 and recently put on the above backhoe to include the "subframe".
    I did it in the record time of 8+ hours but at least it fits and works.
    Unfortunately I am in the dark about what I have to remove from the 3 pt. hitch so I can put the hoe on quickly and I don't what to have to take off more then necessary.
    Could anyone bring me up to speed?
    Thanks, Mike
  2. #2
    Join Date
    Oct 2008
    Posts
    58
    sch'dy, ny
    jd 1026r
    Default Re: 260 Backhoe
    mike
    this is a year plus late but...
    on my 2210 w/ 260
    remove the mmm
    raise the 3pt to it's highest position and set he mmm deck height dial to "lock"
    remove the lower 3pt arms and install 2 spacers; supplied with my tractor; on the shaft in the same location from which the arms were removed - no need to remove the tires as the shaft slides side to side
    remove the top link if installed
    no need to remove the assembly that uses the 3pt to raise and lower the mmm that runs along the left side of the frame as in the locked position the 206 frame will just fit
    total time 15min
    tkoza
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
