2305 wheel spacer
   / 2305 wheel spacer #1
etcallhome
WV,Preston County
JD 1026R
I have a 2305 w/bh ,fel, 54" mmm and front blade. Getting tractor ready for snow plowing I decided to put on my chains. Chains fit but side of chain catches on the head of the bolts going to the sub frame for the bh !
Where could I get wheel spacers ????????
   / 2305 wheel spacer #2
Deere makes spacers for this. The part number is BM18021. I think you will find that the tractor is more stable and sure-footed with these. :)
   / 2305 wheel spacer
Thanks so much for the info. After posting this I had been looking on Ebay and I seen that part # listed for 425,445,and 455. Since I had a 425 I thought it might fit ,Just wanting to make sure before I placed a bid
Some place I read someone had used these on the front wheels ? Was that you ? or do you just have on the rear wheels ??
Thanks again
   / 2305 wheel spacer #4
I use them on both the front and rear. They move the tires out about 1" on each spacer. They were designed for the very issue you are having with chains. These work on the X7xx tractors which have the same wheels as the 2210/2305, and the 425/445/455.
2022 CATERPILLAR 306CR EXCAVATOR (A51242)
2022 CATERPILLAR...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
74in FEL HD Round Back Bucket (A52128)
74in FEL HD Round...
UNUSED CFG Industrial MX50R Mini Excavator (A47384)
UNUSED CFG...
CUSTOM TRAILER (A51242)
CUSTOM TRAILER...
1993 Ford Ranger STX Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
