I finally got all the parts together and installed a rear work light and 12v switched power outlet on my 2305. I borrowed alot of ideas from you guys! I used the cutout that is meant for the cruise control sw for the sw that controls the 12v outlet. I installed a second sw in the blank left of the parking brake for the rear work light. Both circuits are fused and operate thru relays. The relay circuit draws it's power from the #1 wire at the key sw and is only hot when the key is on. It goes from the #1 wire, thru a fuse, thru the sw's and to the relay coils. The power to the light and 12v outlet come directly from the battery, thru a fuse, thru the relays, and out to the loads. May seem like overkill, but I think it's a good design. Sw's are John Deere as is the rear work light. The 12v outlet is a marine outlet I've seen used by a number of people on here. The relays are standard automotive relays. Almost all connector are heat shrink type or sealed with heat shrink tubing. It was dark when I finished and the rear light already came in handy backing into the shed.
