2210 Snowblower vibration
   / 2210 Snowblower vibration #1
Labrat
Gold Member
Central NY
JD 2210
Finally had a chance to deal with the vibration from the mid pto shaft. This is what I came up with. The vibration is totally gone. Still have some chain noise so I plan on trying a motorcycle type O ring chain as they seem to run a little quieter.
   / 2210 Snowblower vibration #2
Looks like a nice job. (Just in time, too!:D ) What is the saddle underneath (pillow block?) Where did you get it? My 2305 seems to be working OK - it gets a little noisy if a shear bolt is loose in the auger.
Yep thats a pillow block bearing. I tried that first but it didn't fix the vibration due to the excessive drive shaft angle so I cut the U joint out and machined it for the cv joint.
The snoblower hasn't run this smooth since I bought it 4 years ago. The dealer already replaced the shaft once but it didn't help.
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2020 TAKEUCHI TB240 EXCAVATOR (A52705)
2020 TAKEUCHI...
1981 LOAD KING BELLY DUMP (A53843)
1981 LOAD KING...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2017 Hino 268 26FT Box Truck (A55788)
2017 Hino 268 26FT...
