Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Silver Member jd4310man's Avatar
    Join Date
    Mar 2006
    Posts
    198
    Scottdale, PA
    Yanmar VIO27-3, New Holland L455, John Deere 655 C.U.T.
    Default 4100;4110;4115 reliability
    I was checking out the John Deere 4100,4110, and 4115 size compact tractors and read in reviews that some guys have had trouble with the front axle prematurely failing with costly repair.Has anyone had any such problems with this? I know that some people think that these tractors are "indistructable" but like anything I understand that one has to use some common sense in what you can do with size machine. Its not a D6Cat!!!
  2. #2
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,924
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Default Re: 4100;4110;4115 reliability
    Welcome to TBN
    I have not heard of any axle problems at all, definitely not on this site anyway.
    My 4110 has been bulletproof...
    The only common front axle problems i remember was with the 4x00 series, like the 4400, 4500, 4600. They had a problem when turning hard they would tear up turf pretty bad. There was a DTAC and they where replaced if the owner complained.
    Where did you read these reviews?
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  3. #3
    Member
    Join Date
    Mar 2004
    Posts
    31
    JD 4110, 2005 Gator TX
    Have to say that I agree with kennyd in that I haven't read anything in the forums about axle problems in the 4100/4110/4115 tractors. My 4110HST has been trouble free since I purchased it in 2003. I have been very pleased with it and am amazed at what I have accomplished with that tractor on our property and on my neighbors' properties. My wife uses it as much as I do, so I'd have to comment on it being "user-friendly", as she wouldn't go near our old tractor.
  4. #4
    Member
    Join Date
    Sep 2007
    Posts
    32
    Upper Valley VT
    JD 4115
    I bought a 4115 back in 2002, So far no major problems. Great little machine. I originally bought it to snow blow the driveway but I ended up also buying the FEL and I am continually amazed at what I can do with it. back in November I used it to lay down 63 tons of hard pack on my drive. I am definitely very happy with it.
  5. #5
    Join Date
    Dec 2001
    Posts
    1,060
    Minnesota
    JD 4100 HST
    My 4100 developed a slow oil leak in one front axle seal. Nothing major, but it was annoying and messy. It looked to be corrosion related - I had to clean up the some pitting on the shaft as well. New parts were cheap enough and I was able to do the work myself, but I would have thought it would go a bit longer before having problems. Tractor is a 2000 and had about 700 hours at the time.
    - Rick
  6. #6
    Join Date
    Mar 2006
    Posts
    198
    Scottdale, PA
    Thanks for all of the replys. I was reading on ********************.com and found that a couple people have had some problems with their front axles, what they were doing with their tractors to cause such problems is a mystery to me?
  7. #7
    Veteran Member JDGREEN4ME's Avatar
    Join Date
    Sep 2002
    Posts
    2,245
    Southeast PA
    John Deere 2520, John Deere X534, John Deere LT150
    I've owned both a 4110 and a 4115 and did not have any big problems with either one. The only thing I can remeber was one of the hydraulic valves on the 4110 loader went bad. Did not cost that much to replace and I was able to do the change myself. Right now I am "tractorless" and I would take either one back in a heart beat!
    "We can judge the heart of a man by his treatment of animals"
    Immanuel Kant
  8. #8
    Join Date
    Jul 2003
    Posts
    12,924
    Westminster, MD
    I just checked that site, I had never been there before. But I did read the review about the axle, he also cautioned about rear ballast...and I bet that is what caused his axle failure-lack of rear ballast or using the MFWD (4wd) constantly on hard/paved surfaces. Even his dealer had never seen the problem before...
    KennyD
    www.boltonhooks.com
  9. #9
    Elite Member RalphVa's Avatar
    Join Date
    Dec 2003
    Posts
    4,750
    Charlottesville, VA, USA
    JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
    Absolutely no problems with my 4010. It's just a lower hp version of the ones you listed. Almost 300 hours.
    Moved my ROPS lights inside. Have lost the front PTO cover twice and found and replaced it both times. Lost bottom lift arm collar and pin on one side, just as I've had pins come out of a lift arm occasionally.
    Some folks have reported broken U-joints between engine and HST on the 4010.
    Ralph
    The natural gardener
    God's original intent
  10. #10
    New Member
    Join Date
    Feb 2005
    Posts
    13
    Finksburg, MD
    JD 4115
    My 4115 runs great, no problems. had a line for the power steering leak but the dealer handled it.
    JD 4115, 410 FEL, 60" MM, iMatch. Ballast Box, KK 5' Rotary
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
