NYBOB
I have a 3720 with a 300CX loader. They put on a JD skid steer adapter on the loader arms. It worked fine until I had them put the 3rd SCV on and hook up my snow plow. The first time I took the plow off to put my bucket it on, I noticed the arms were not moving at the same speed. This makes if difficult to line them up together to get on the QA plate. I showed the dealer and said there might be air in the hyrdaulic lines and should work its way out. It has been 2 months now and still doesn't work right.
Also, when I had my New Holland the ATI skid steer adapter they used was one solid piece, The JD is two. I thought about having someone weld a piece across them to make them go in sequence.
What might the culprit be so I can tell the dealer?
Thanks
Thanks
