hemiguy
Hi folks,
I finally got to change the hydro oil in my 2520. It really should have been done at 50 hrs as per the manual but it has 95 hrs on it now. Shame on me, but you can't do it with the BH on. I had the BH off again this week and finally made time to do it.
Now for the questions. The magnetic suction screen filter had a LOT of fine metal bits in it. Way more than I expected to see, but is this just normal business as usual with all those non-syncro'd straight cut gears in the transaxle? In other words, the magnets are in there for a really good reason? The transmission and hydraulics seem to work fine both before and after the fluid change, but I just didn't expect to see that much metal coming out of there. Took me quite a while to get it all cleaned up.
Next issue is the darned owners manual again. I looked over the section on transmission service before buying stuff and doing the change and was scratching my head cause the pictures and descriptions in there look nothing like my 2520. So I took the manual to my dealer and he had a newer revision one that actually had the correct procedure so he copied those pages for me. Now keep in mind, mine is also the manual that says to put in 3 qts of engine oil when it really needs 4 qts after changing. The dealer is going to "try" to get a new (correct) manual for me under warranty. Come on JD, please get your act together.
Anyway, any similar experience with the crappy 2520 manual and some metal in the hydro suction screen?
