Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. #1
    Gold Member Mech's Avatar
    Join Date
    Jan 2007
    Posts
    409
    Pine, CO
    3520 CAB
    Default Unhappy about Starting at High Altitude
    Sent this email to JD. No answer yet but wondered if you think I'm being too picky? I'll let you know if/when JD responds.
    I bought a new 790 with loader, box blade and front blade last year. It now has 50 hours on it. I live at 8600 feet and it will not start unless I use the block heater or the intake heat. Last night my block heater burned up and I've ordered another one for $60. Now the dealer is telling me it probably needs to have the timing changed and it is going to be big $'s to get that done as I'm 90 minutes from the closest dealer. I think it is outrageous that I buy a brand new tractor and it won't start in any temperature w/o a cold starting aid which burned up in less than a year. Is JD interesting in somehow making this good?
  2. #2
    Platinum Member tomd999's Avatar
    Join Date
    Jul 2007
    Posts
    666
    Viva Manchvegas!
    '10 3320 cab
    Default Re: Unhappy about Starting at High Altitude
    Hi,
    What's "normal temperature" where you are? If it's under 50, it's not that out of line that it would require cold start system usage. How does it start after being used and it's still warm? Also, using a fuel additive that boosts cetane will aid in cold starting.
    Hope that helps,
    Tom
    Big and little Green tractors, Orange tractors and one awesome brown dog.
    "Congelo nos opus, quantum punitor ingravesco"
    "Behold, like the wild azz in the desert, go I forth to my work"
  3. #3
    Join Date
    Jan 2007
    Posts
    409
    Pine, CO
    3520 CAB
    It needs the block heater or intake heat at all temperatures. Highest it gets here is about 85 deg F. Over 70 during the day for most of the summer.
    I do use a fuel additive and it hasn't made a difference.
    It starts easily after running for more than a minute or two. Runs great after it warms up.
    I was willing to live with it until a dealer (another dealer not mine who has always said just keep it plugged in) told me that they had to do a timing change for others in the mountains. My dealer knew my altitude and I felt they should have done that for me or at least not just kept saying to keep it plugged in.
    If I'm going to go thru a $60 block heater ever year I would like to get it fixed but I don't want to spend a $500 to $600 service fee for it. I could just use the block heater for the coldest nights and use the intake heat at other times but I don't know how long that element will last and I would guess it is more than $60.
  4. #4
    Platinum Member bx24's Avatar
    Join Date
    Jan 2006
    Posts
    668
    Indiana
    Older over the road trucks used to have Ether start bottles on them. I wonder if you hooked one of these up if it would work for you (and save you a bunch of bucks). You have to be careful not to use more than a small "squirt", but it made a world of difference in starting larger engines.
    This is what I found when I did a quick search .... sorry no prices but I bet it is less than $100 bucks
    Good luck
    Attached Thumbnails Attached Thumbnails Unhappy about Starting at High Altitude-ether-kit-jpg
    BX24
  5. #5
    Join Date
    Jan 2006
    Posts
    668
    Indiana
    Here is another company (with a phone number) .... See what they think
    Attached Thumbnails Attached Thumbnails Unhappy about Starting at High Altitude-ether-kit2-jpg
    BX24
  6. #6
    Silver Member Racer71's Avatar
    Join Date
    Oct 2007
    Posts
    240
    Peyton, CO
    Kubota L3400 HST
    I live at 7,000 and I can't believe the altitude makes that much difference. It should light right up with glow plugs. Maybe a block heater under 30. Any heating element should last more than 1 year. The equipment is designed to last 30 years. Does the engine have a turbo?
    Colorado Stan
    Kubota L3400HST, FEL, Rear Blade, Box Blade, Snow Blower, Brush Mower, Tooth Bar, Ballast Block, Still looking?
  7. #7
    Join Date
    Jan 2007
    Posts
    409
    Pine, CO
    3520 CAB
    Quote Originally Posted by bx24
    Thanks for this. I need to check whether it will void the warrantee but if not it might be an alternative.
  8. #8
    Join Date
    Jan 2007
    Posts
    409
    Pine, CO
    3520 CAB
    Quote Originally Posted by Racer71
    No turbo and no glow plugs. This engine just has an intake heater. I had a Yanmar 1610 last year, just a smaller version of the 790, that acted the same way and the dealer ended up taking it back. It had other problems but I thought the starting problem with it was low compression. Looks like it was just the altitude. We discussed this on this forum before and someone said they had diesel engines in Aspen that required an altitude compensation turbo to start. I checked on those and they are cost prohibitive. Looks like I just use the cold start aids, ether or get the timing adjusted.
  9. #9
    Join Date
    Jul 2007
    Posts
    666
    Viva Manchvegas!
    '10 3320 cab
    Hiya,
    Whow, don't use a quick start kit on that little Deere, you'll run the risk of making some bad things happen. Those quick start kits were made for the older Diesels in the 60's and 70's like a Detroit 71 series. The injector pumps and injectors were lower pressure and they would suffer from poor cold starting.
    I looked on the Deere and Yanmar site and the engine listed for the 3005 is a DI type so it should light right off after a few seconds of cranking. I have found with the DI engines I run is if the primary fuel system has an issue they tend to be tough starting after they sit for a day or 2. The Cummins B series suffers from this issue if the lift pump or the primary low pressure supply line leaks down.
    Check your supply side from the tank cap all the way to the low pressure supply port on the injector pump. Make sure you have the pressure and flow specs right. You may have a leak down issue where the supply to the pump drains down away from the injector inlet and your cranking for several seconds until the low pressure supply restores fuel to the injector pump and therein supplies high pressure fuel to the injectors.
    Hope it helps,
    Tom
  10. #10
    Gold Member shot_gun's Avatar
    Join Date
    Mar 2008
    Posts
    386
    NJ
    I have a couple thoughts... If the block heater was installed by the dealer it should be covered under warranty. Travel time won't but be the job should be. Unless you bought MPP. Ether is for emergency only. I've seen the rings in a tractor look like someone took a torch to them because of ether. Time may help but I would want to check the timing first to verify it is were it should be. I would ask your dealer to put in a DTAC case on it if he hasn't already. That is the dealer resource when they have an oddity they can't figure out. 50 hours is time for your fist service. Maybe let the dealer do everything in one shot? Your problem must altitude related because even when it's cold here the 790's still start with just the preheat. Granted we are only 120 feet above sea level Let your dealer do their job.
    S_G
    Remember nobody ever complained about having too much horsepower!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
