kennyd
Advertiser
klink said:Kennyd
Mid lift assist kit for 4100 & 4110 part # LVB25010
I went to the dealers lot and looked at the lift cylinder kit on the 4200 JD tractor. It looked good and well made. I knew the 4110 kit would be different, but didn't realize how under engineered the 4110 model lift kit would be.
The kit includes an under engineered one way lift cylinder that barely has enough lifting force to raise the deck. and because the cylinder bore and stroke is so small, it does not hold much volume of oil in it, or have enough force. The cylinder [deck]would leak down in seconds. I even installed a needle valve in the hose going to lift cylinder to trap the oil in the cylinder, once it was in the raised position. I had it hooked up to my tractor's dual scv. Also the lift brackets are poorly made. The engineer who designed this kit did not have JD customer satifaction in mind. As most of you know the 4110 does not come with a mechanical mmm level or lock up kit such as the [2000 series]. JD did update the indepentant mid lift kit for the 2520 tractor, which has the simular rear end. This tells me JD knew the first kit was not doing the job.
When I got my JD 46 backhoe, I took the lift kit off and installed the 3 pt. lock up kit, which work great and is the best option for my tractor use.
this is my opinion only
Thanks a lot for sharing this...
