Runner
Elite Member
- Joined
- May 12, 2007
- Messages
- 3,181
- Location
- Missouri
- Tractor
- 2024 Cub Cadet Ultima ZTXS5 54, 2007 John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
I just did the 50 hour service on my 2520 and have a couple of questions.
First, the manual says there are two drain plugs for the transmission and rear axle housing. I only found one (see picture). Does anyone know where the other one is located? Are they talking about the plugs on the bottom of the final drives? If so, that would make three.
Second, the book says there is a spring behind the access plate for the suction screen, but I didn't see one when I removed the plate. My suction screen seems to just fit tight into the wells on each end. Also, there were only two bolts holding the plate, not four as in the manual. Is yours like this?
As others have noted, the pictures in the manual don't really match the tractor (for one thing, half the pictures are of a 2320).
