Results 1 to 10 of 28
07-13-2008, 08:10 PM #1
My 2320 Seat Fix
An update on my seat experiment, I purchased two seat suspension springs from JD (M153100 for and X series standard suspension) that were roughly the same base diameter as the rubber under the seat. I pulled the rubber and put in the springs and used a fender washer and small bolt at the bottom of each spring as a keeper and the ride is day and night. Rides like a it should have when new. I had cut the tops of the springs a bit to make it level when I am sitting on it. Overall took about 15 min and $12.64 to make a decent ride.
It is a cheap fix and cheap experiment. I mowed a bit today to try it out and my back it thanking me.2011 JD 2520 | 72" MMM | 200CX FEL 73" bucket | JD 54" Fr Blade | Michigan Suspension Seat | SpeeCo Q-Hitch | JD Ballast-Box | 5ft King Kutter Brush Cutter |
07-14-2008, 02:17 AM #2Platinum Member
- Join Date
- May 2007
- Posts
- 838
- Location
- eastern PA-lower Poconos
- Tractor
- JD2320 w/R4 $21,100 w/7.16%off
Re: My 2320 Seat Fix
I'm saving your posting for when my rubber mounts give out.
Eastern PA -JD2320 w/R4; 200CX w/61" bucket & Markham toothbar or JD adj forks; 46BH w/16", Imatch, ballast box & York rake-blade-scarifer, 54" front plow and trailer receiver. Case 580K w/fel+bh, mule 610XC
07-14-2008, 09:20 AM #3
You could be waiting quite awhile
07-14-2008, 10:51 AM #4
No pictures?...Shame on you
John Deere 4110HST
FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
John Deere 4x2 Turf Gator
View some of my projects/adventures in my Picasa Album
Simple JDParts Tutorial HERE
07-14-2008, 07:42 PM #5
Well, darn me. I will get some on here tomorrow.
07-15-2008, 10:39 AM #6
Here is a picture of the springs installed.
07-17-2008, 04:30 PM #7
Forgot to mention and it did not show in the photo but I glued thin rubber disks under the seat (where the old rubber springs rode) so the springs did not contact the metal of the seat. So far so good, no problems but a smoother ride.
07-19-2008, 11:22 AM #8Silver Member
- Join Date
- Nov 2004
- Posts
- 164
- Location
- Lincoln, VT
- Tractor
- 2007 JD 2520
Great idea - just ordered mine and will let you know how it works out. Thanks for posting
Brad2007 JD 2520 R4 Loaded / 200cx -61" HD Bucket with tooth bar / Frontier RC 1048 Cutter / Frontier LR 1072 / iMatch
07-19-2008, 08:29 PM #9
Thank you. I have about 8hrs seat time on this setup so far, no complaints and everything is working just fine. Let us know how your setup works for you.
08-05-2008, 09:03 PM #10Member
- Join Date
- Feb 2007
- Posts
- 29
- Location
- wi.
any update on the new seat?
John Deere 2305, 62''MMM, 200CX Loader, I-Match, Frontier RB2060, Ballast Box, Tooth Bar(homemade),Aux Work Lights, 403 JD Rotary Cutter, Towbehind Sprayer, STIHL 290 20'' bar, STIHL 210 16'' bar, STIHL FR55S, STIHL Power Broom
