jdmar
Gold Member
I have a 430 loader that now doesn't load! For the last week or so the lift cylinders will not lift or push down (as when using loader to stabilize backhoe). Problem is this has been intermittent. Often it is a problem when first starting the tractor--then if I cycle the SCV many times it will lift totally normally. By normal I mean a full load to any height with nearly no drift down...like nothing was ever wrong! I previously rebuilt my curl cylinders but they drifted all the time...these don't act like that.
When the lift cylinders are not working, I CAN lift the loader only if empty and with the engine speed revved up high (2000 + RPM). It lifts very slowy, but does seem to hold it's position..that is it does not drift down even when it took high RPMs to get it lifted up. If I push the SCV forward it does come down very quickly.
Also, if I push the engine RPMs up and try to lift the loader arms AND curl or dump at the same time the arms will not lift (or will drift down if already up) but the bucket curls fine. I also have a 47 backhoe on that has zero problems.
Sorry for all the details but I know there are lot of people a LOT smarter than me and they may need details to help. By the way, I did order lift cylinder rebuild kits since they are a lot cheaper than fixing the SCV. I will pick up the repair kits Monday, but something tells me that is not the whole fix. I don't see why the system either works fine...or not at all, and can switched back and forth.
Maybe I will try switching the SCV lines to see if the lift then works and the curl doesn't...that would help tell me if the problem was in the SCV or the cyclinders...am I right in this thinking? Thanks ofr any help or ideas. I hate taking this to the dealer if I can avoid it...I hear the SCV repair is very expensive.
Peter
Peter
