Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > John Deere > John Deere Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-04-2008, 11:05 AM   #11 (permalink)
art
Elite Member
Default Re: John Deere Auto Connect 72" MMM
Two minutes isn't bad, still looks like about the same amount of steps as most mowers. How low is the PTO on the tractor?
art is offline   Reply With Quote
Old 11-04-2008, 04:25 PM   #12 (permalink)
PTO up and down pics. I think they did a good job of getting up out of the way considering the amount of space under the tractor. You could easily remove the lift mechanism. It's just 2 bolts and 2 pins.
john-deere-auto-connect-72-dscn3419pto-height.jpg  john-deere-auto-connect-72-dscn3420pto-height-2.jpg
jsboening is offline   Reply With Quote
Old 11-08-2008, 07:37 PM   #13 (permalink)
Elite Member
I am very impressed, very impressed. Now if i could fine one used and trade in my 2006 7 iron, etc! LOL!
__________________
Nuru
JD 3520
Nuru is offline   Reply With Quote
Old 12-25-2008, 05:06 PM   #14 (permalink)
Elite Member
Builder's Avatar
I am about to need a large mower to replace my tiny GT325. I really don't want a zero-turn mower. I think they're just kinda nerdy looking
I dreaded a 72" or 84" MMM because they look really difficult to remove for cleaning.
Once the drive over type MMM's came out, I thought there was hope for me. I just wish there was a quick way to clean them & change the blades.
__________________
'00 New Holland LB115 4x4 Backhoe: 108HP, Powershift. Cab-AC, 4WD/4WS, posi front/rear axles, 4in1 FEL, X-hoe, Aux hammer hydraulics, Gannon compactor & buckets.
'05 AGCO/Challenger MT285B 4x4 CUT: 48HP HST, Cab-AC, 4in1 q/a FEL w/ aux hyd, 90" Landpride Power Rake, 8' Meyer P/A snowplow, Herd spreader.
'07 GMC 3500 SRW 4x4 Crewcab SLT: Dmax/Ally, utility body
'92 IH 4800 4x4 Dumptruck: DTA-466 at 250HP, airbrakes, 7 sp w/OD, Fabco front axle & transfer case, airbrakes, 12' dump, 33K/56K GCWR.
Builder is offline   Reply With Quote
Old 12-25-2008, 08:23 PM   #15 (permalink)
prosperity's Avatar
Quote:
Might be the looks don't appeal to you, but once you've tried one, I think the performance will overcome the "looks"!
Try it - you might like it - I know I could never go back to a belly mower for finish mowing.
prosperity is offline   Reply With Quote
Old 12-25-2008, 08:51 PM   #16 (permalink)
Elite Member
Builder's Avatar
I know you're right.
I only have to go back to the summer I spent mowing with a diesel Excel Hustler FMM to understand exactly what you mean. That thing could cut grass faster than anything I've ever seen.
__________________
Old 11-06-2009, 08:41 PM   #17 (permalink)
New Member
I just ordered my new 3520 two days ago with the older style 72" 7-Iron, and after reading your post I went back today and changed the order to the Auto-connect. As it turns out they are discontinueing the old deck anyway.
I was wondering if you still think its a good setup since its been about a year since the last post. Any thing to look out for as things "wear in" My only concern was the coupler where the driveshaft mates only has a few splines. How's yours holding up??
I guess i'm hoping to hear I made the right call on the upgrade...
Thanks
cowboy_79_1999 is offline   Reply With Quote
Old 11-07-2009, 10:24 AM   #18 (permalink)
ChuckinNH's Avatar
You made the right call on the upgrade! Now that you have heard it, let's hope that it is true. Seriously, it sure looks like a slick set up.
__________________
B2620,Loaded R-4's , Wallenstein BX42 chipper, Bush Hog SQ148 RC, 4' x 8' chain harrow, Simplicity Legacy with 48"mmm, turbo collector, Country Line carry all, Countryline Middlebuster, Woods 48" BB, Kubota QA for loader, Kubota forks, and more to come...
ChuckinNH is offline   Reply With Quote
Old 11-18-2009, 12:22 AM   #19 (permalink)
New Member
Picked up my 3520 tractor on Friday and after some initial tweaking adjustments on the MMM lift system, I must say that the 72" auto connect deck is awesome!!! I finally got the leaves mulched. Driving on and off of this deck is a breeze, and with the easy on/off of the 300cx, this tractor is quickly converted from mower to loader. I can not believe how powerful and maneuverable it is for its size. A HUGE improvement over the old IH 184 i was mowing with.
Old 11-18-2009, 12:17 PM   #20 (permalink)
New Member
Cowboy - Congratulations on your new 3520!
I知 also considering the same setup (3520 open station w/72D). My biggest concern on the 3520 is the narrow wheel track and total weight for side hill mowing stability. Currently my Deere 870 with loaded tires set to the wide wheel position at 64 outside wheel track has proven to be adequate on my terrain.
Perhaps you can help with some questions.
1) Which tires did you select and do you have any side hill performance comments to share?
2) I see from jsboening pictures his front turf wheels are set to the narrow position. Can the 72" auto connect deck accommodate the front 2 position wheels set to the wide position?
3) Does the 72D manual have any rear wheel/tire restrictions? I can稚 tell from jsboening pictures if his rear wheels are set wide or narrow. Does your 3520 manual give track width for both wheel position settings?
4) I知 also from PA. Which dealer did you use? Can you please share your configuration and pricing???hanks
Briarcreek is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.28672 seconds with 9 queries
