Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Join Date
    Oct 2004
    Posts
    133
    New Jersey
    Default ballast box and quick hitch
    Hello all,
    How much do the JD ballast boxes usually cost? Also, has anyone bought one of those non-JD quick hitches, like the ones on Ebay? If so, how do you like it?
    Thanks,
    Ryan
  2. #2
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,924
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Default Re: ballast box and quick hitch
    The JD ballast box's are about $220.00 or so now do the the price of steel. I have the real I-Match myself and wouldn't buy anything else. There are LOTS of threads about the ones from Horrible Fright and others like the Speedco unit that TSC sell if you do some searching...
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  3. #3
    Join Date
    Oct 2004
    Posts
    133
    New Jersey
    Quote Originally Posted by kennyd View Post
    O.K. I'll have to do some searching on the other brands of hitches
    Thanks
    Ryan
  4. #4
    Join Date
    Feb 2008
    Posts
    125
    Southern MD
    BX2380
    I had a Deere I-match, sold it and bought a Speeco quick hitch from Tractor Supply. No doubt the Deere hitch is prettier, with a better quality paint job, and they cleaned the welds up nicer, however, the Speeco unit is just as stout, and ADJUSTABLE. The Speeco unit also came with the u-shaped upper link that allows you to adapt non quick-hitch ready items to your quick hitch. I've got a finish mower and a rotary cutter that I use with this upper link, they work great. For everything else, I toss the hook on. If you have an implement that has a higher or lower top pin, you can move the hook up or down. So, if everything is "I-match" compatable, no reason you can't go with the I-match. If you need some adjustability, go with the Speeco. BTW, I think the harbor freight unit is probably made by Speeco. The fitment problems folks had with them was due to the fact that they offered two units, one of which was an inch narrower, which was too narrow based on cat 1 specs.
  5. #5
    Join Date
    Jul 2003
    Posts
    12,924
    Westminster, MD
    Quote Originally Posted by Birdmayon View Post
    Not to start a war-but in my way of thinking the "adjustability" of the Speedco and the HF unit makes it not a "quick-hitch" if it needs to be adjusted to fit different implements. For me-modifying the implement once to fit the ASAE standard is a better solution, or if your starting from scratch just make sure the new implement meets it assures you won't have to adjust anything-making for a true "quick-hitch"
    KennyD
    www.boltonhooks.com
  6. #6
    Super Member JB4310's Avatar
    Join Date
    Feb 2005
    Posts
    5,645
    Central CT
    J.D. 4310 E-hydro
    I have the i-match and had to mod a few things but now they all work, also got a harbor freight unit for an older machine, fairly well built but not compatible with the bushings used for i-match mated implements, had to take 1/4" + from the lower j-hooks opening and 1/8 from the top hook. not an easy task! I wanted to be able to use all implements with both tractors.
    Worst thing about the HF unit is the way that top j-hook is made adjustable, with the 2 bolts it is impossible to engage the top pin on my JD blade and my landpride rake, had to remove the bolts and just force oversize pins in their place that do not extend outside the top j-hook mounting members.
    As far as that special link needed for the mowers goes I now understand the issue, it doesn't affect me but I see why some would not be able to use the i-match.
    I was grinding the lower j-hooks again today, if I knew how much work I would have to do I would have just spent the extra money for the i-match.
    Overall I'm OK with the HF QH as it only cost 79. I think i-matchs are close to $250. now.
    JB.
    JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 48", 61"HD & 73" high volume bucket.
    FORD 1700; 2 WD, 2600 hrs.
    JD 320; Hydra lift, 48" deck and 48" snow blade.
    2007 Dodge Ram 3500, Cummins 6.7L, Aisin 6 speed, 9ft utility body.
  7. #7
    Join Date
    Feb 2008
    Posts
    207
    Redmond, WA
    JD 2320 w/200cx loader w/53" bucket
    I have had the iMatch and both Harbor Freight cat 1 models. The 27.5" HF model is the best in my opinion (the original is 26.5 which is too narrow). I returned the iMatch because you have to have adapter bushings for everything and that is a pain when you have no local supplier - my dealer had none of the right width on hand for even the Frontier box blade they sold me, and the finish on it wasn't that good - lots of rust. I replaced the bolts holding the top hook on the HF with pins to make it easy to adjust, although I don't need to - and no special bushings are required.
  8. #8
    Join Date
    Feb 2008
    Posts
    125
    Southern MD
    BX2380
    No war, you're right, it does make it non-quick hitch in a sense, however I don't have the means to modify my equipment, and I also like buying used rather than paying the bloated prices for Frontier equipment, so I have a couple of things that are not quick hitch compatable out of the box. Actually I do have a Frontier finish mower, which does not have the quick hitch kit on it (that is a $200 option by itself). With the top link adapter on the Speeco hitch, I can use that finish mower. Can't do that with the I-match because the top link adapter would hit the J-hook on the down stroke, since the hook is not removeable.
    Big thing for me is the Speeco, while not truly a "quick hitch" in the sense that I need to adjust the hook, still makes life very easy, never have to adjust sway links, and with about 30 seconds of prep work I can switch between all of my implements.
  9. #9
    Join Date
    Jun 2006
    Posts
    784
    A Jersey Boy Exiled to MA
    John Deere 2520
    In my opinion there are two options:
    1. Be prepared to modify things and use an iMatch
    2. Cover the bulk of the quick hitch issues and get Pats easy change hooks
    For me it's always been quality over price, so the iMatch would be my choice because it's built to the ASAE standards while the others usually require some fine tuning with a large sledge hammer. The Landpride clones with the adjustable toplink support are nice, but they still don't allow for different sidelink widths and if I need to make an adjustment anyway it's just as easy to hook up a hydraulic toplink (and more fun, I get to play with levers!). With Pat's I can back up to the equipment and connect the sidelinks from the seat and then I just need to connect the toplink - I don't change implements enough to bother with modifying my stuff but it's still on my list of things to do.
    Thanks,
    Jeff
    JD 2520, 62D OnRamp MMM with MCS, 200CX Loader with 53" bucket and forks, RT1250 tiller, DR PTO Chipper/Shredder, iMatch/Pat's EZ Change, 46 BH, Top-N-Tilt
  10. #10
    Veteran Member Runner's Avatar
    Join Date
    May 2007
    Posts
    1,682
    Missouri
    John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
    I have an iMatch and love it. Since I bought most of my stuff when I bought the tractor, I just made sure to get attachments that were compatible (Frontier). As for the two things I have that are not compatible (KK rake and carryall) I made an interface adapter that goes between the attachment and the iMatch.
    Attached Thumbnails Attached Thumbnails ballast box and quick hitch-4-27-08-006-b
    Runner
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
