Transmission Drain Plug Size?
   / Transmission Drain Plug Size? #1
Ichabod
Member
Would anyone happen to know the size and pitch of the transmission drain plug on a JD 2305 tractor? I can't seem to find this information on the JD website ... I have looked and looked. Thanks for any and ALL help ....
Ichabod
   / Transmission Drain Plug Size? #2
I take it you can't find yours?
I think the cat ate it; or, the dog took it and buried it!!
Ichabod :eek:
   / Transmission Drain Plug Size? #4
My 2320 (which i am pretty sure is the same engine) is a 16mm x 1.5. I recently installed a Femco drain valve on it and verified it with the dealer before I ordered the plug
good luck
Brian
thatguy,
are you referring to the "engine" or the "transmission" drain plug size? i read it as you're speaking of the "engine" drain plug size as 16mmx1.5 ... i need the "transmission" drain plug size ... unless they are both the same? some clarification please?
tx
(confused :confused:) Ichabod
   / Transmission Drain Plug Size? #6
thatguy,
tx
DISREGARD - I misread your original post - what i posted was the engine oil drain plug size.. sorry for that..
Brian
   / Transmission Drain Plug Size? #7
The best I can figure from parts diagram is 12mmX30mm long. It is part number
LVU800462. It does not give specs on thread pitch. The gasket part number is M808459. I hope those are correct numbers. The diagram is not too clear. Item numbers 39 and 40.
40ft High Cube Shipping Container (A57453)
40ft High Cube...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
New/Unused 2025 CFG QK18R Mini Excavator (A57453)
New/Unused 2025...
2003 Big Tex 10PI...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
