Results 1 to 5 of 5
  1. #1
    Bronze Member johnnydel29's Avatar
    Join Date
    Apr 2007
    Posts
    89
    East of Albany, NY
    JD 2305
    Default Loader Mounted Snow Plow for 2305
    I have be wanting to build a snow plow attachment for my 200cx loader on my 2305, I finally had to opportunity to do so, and I thought I would share.
    Last week I was fortunate enough to come across a used 60" ATV Plow, manual tilt. I went to a steel shop, picked up some 3" x 3" 1/4 & 3/16" angle irons and 2"x3" 3/16" square tube (I realized I could have used all angel irons). I also, picked up the brackets and pins that fit the loader frame from deere. So I cracked up the salamandor jet heater in the garage this past weekend and went to work.
    The trickiest part was lining everything up and making sure the brackets and pins line up with the loader frame. My dad helped me, which made the job a lot easier. As you can see, I basically built a frame to fit the loader arms. Then I welded the plow to the angle iron and added to smaller 1" x 1" angles to serves as braces. Everything worked out well, I tested it, and it works awesome. The atv plow is perfect for this machine - it is not too heavy. For now, since it is so cold - I am going to hold off on painting everything, I'll save that for the spring. Also, I plan on cutting the angle Irons slightly at each end, just to make things more uniform. The plow itself also needs to be straightend out a bit, since the provious owner abused it quite a bit. My nieghbor owns a body shop and has offered to do so, using his car frame straightening machine.
    After testing it moving some piles of snow along my driveway - I am real pleased with how it works. I also like this system becasue since my driveway is gravel, I can float the loader so I do not pick up a lot of gravel.
    The entire cost for materials was about $350.00. The biggest challenge is finding a used plow like this - it almost took me a year.
    We are suppose to get a snowstorm this week - so I'll definitely be able to put it to the test!
    Attached Thumbnails Attached Thumbnails Loader Mounted Snow Plow for 2305-plow-jpg   Loader Mounted Snow Plow for 2305-bracket-pins-2-jpg   Loader Mounted Snow Plow for 2305-bracket-pins-jpg   Loader Mounted Snow Plow for 2305-plow-weld-jpg   Loader Mounted Snow Plow for 2305-loader-frame-jpg
    Loader Mounted Snow Plow for 2305-copy-test-plow-jpg
    JD 2305, 54" MMM , 200 cx loader
    Woods 60" landscape rake
    4 x 4 Harrow drag
    Husky 357XP Chainsaw
    Lincoln Pro Mig 180T welder
    Harris Oxy/ Acetyl cutting torch
    Rigid Chop Saw
    Huge Garage w/ a Nice Work Bench
    Husky Gas Power Washer (good investment, get one)
    5 acres - cleared and wide open
  2. #2
    Platinum Member JDeerekid's Avatar
    Join Date
    Sep 2004
    Posts
    877
    P-Town, Upstate New York
    Montana 4340C w/Loader, JD GX345 w/54in. mower
    Default Re: Loader Mounted Snow Plow for 2305
    Nice job!!! Add a little paint and it would look like a million dollars Looks like it matches the tractor perfectly. Yes I agree that you should cut down the angle iron on the ends. I know If I let them stick out that I would be hitting something when trying to get to close with the blade.
    Are you going to add power angle in the future?
    Montana 4340C w/loader, AgroTrend FU78 rear snowblower with hydraulic shute rotation, Horst 48" pallet forks, 3pt. 2-bottom plow, 6ft. bush hog rotarty cutter, 3pt. Woods 7ft back blade, 3pt. cultivator, 5ft 3pt. york rake, 6' KKII tiller, JD494 4-row planter. Future attachments: backhoe, grapple
  3. #3
    New Member
    Join Date
    Jul 2007
    Posts
    3
    RIGA, NY
    3320 w/300CX
    looking good !! I`am thinking about building a loader plow myself, you wouldn`t happen to have the part numbers from john deere for the top curved mounting brackets and lower pins ? they should be the same for a
    300cx loader.
  4. #4
    Join Date
    Apr 2007
    Posts
    89
    East of Albany, NY
    JD 2305
    Hi JDMIKE - I do not have the loader pins and bracket part #. what I did was bring the loader manuel to the dealer and showed them exactly what they were.
    Also - If plan on doing this also - use all 1/4" thick 3" angle iron. No need to use square tube - it is expensive not necessary.
    I have no plans to add a hydrylics to plow at this time. I think it will be ok for now.
    4 x 4 Harrow drag
    Rigid Chop Saw
  5. #5
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,911
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Quote Originally Posted by JDMIKE View Post
    300cx loader.
    Quote Originally Posted by johnnydel29 View Post
    Here are the part numbers for the hooks and pins:
    W43359 HOOK, BUCKET ADD 23.63 USD
    W47211 PIN, BUCKET ADD 28.35 USD
    The price has gone up A LOT since I bought mine a couple years ago...If was building something today, I would just use 1 1/2" angle iron for the top hooks, and cut-off CAT3 pins from TSC for the pins.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
