Ramairfreak98ss
I think my manual said something like it was a 4000lb capacity ?
Not sure why im thinking of that number, just just for kicks.
If i take the pallet forks on the 400cx loader, lift up ~2600lb of weight, even with an extended ballast box on the back filled to the top with concrete on a 4720 cab, it still has teetered on the front axle, i mean lifts the back end of the tractor up a couple times so i lowered the load.
Thats assuming 5000lb tractor, 1400lb ish weight on back, driver 175lbs, fuel
load of 2600lbs is
well over 9,000lbs on the front two tires/axle. Do they just not want to you drive around with it like that for a whole day straight or is it ok to unload a skid off a truck and move it 20ft to sit it down?
load of 2600lbs is
