Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    New Member
    Join Date
    Nov 2007
    Posts
    19
    southeast Pa.
    Default 50 hour service
    I changed out my transmiision fluid on my 2520. I used the recommended HY-Guard oil not the low vis Hy- guard. The oil that came out of my was red. The Hy-guard I put in was not. Did I use the right oil?
  2. #2
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,913
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Default Re: 50 hour service
    Yes, you used the proper fluid. The red stuff is what Yanmar put's in them at the factory to better see leaks I was told, the HY-Guard is almost clear.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  3. #3
    Join Date
    Jun 2006
    Posts
    1,437
    Wheeling, WV
    2006 JD 3520 w/cab & 300CX loader. 1995 JD 870 w/440 loader & 8b backhoe.JD 455 w/54" mower deck.
    As long as you used the correct spec oil you are fine. Cat uses red hyd oil from the factory in some of their machines. Cat's reg hyd oil isn't colored. I'm not aware of any Deere colored hyd oil,but that doesn't mean it's not out there. Probably from the factory.
    Sincerely, Dirt
    "Good judgement comes from experience.Experience comes from bad judgement."
  4. #4
    Elite Member RalphVa's Avatar
    Join Date
    Dec 2003
    Posts
    4,645
    Charlottesville, VA, USA
    JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
    Our dealer recommends the low vis HyGrade here in Virginia.
    Ralph
    The natural gardener
    God's original intent
  5. #5
    Super Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
    That's what I was told about the red color in the hyd fluid, too. They add a bit of ATF to see any leaks.
    AKfish
  6. #6
    Veteran Member Gizmo2's Avatar
    Join Date
    Jul 2006
    Posts
    1,918
    New York
    JD 2320
    Quote Originally Posted by RalphVa View Post
    Ralph
    Dealer here in New York also recommends the Low-Vis also.
    JD 2320, 200CX FEL/61" bucket , 46 BH/16" bucket, FEL Forks, 72" Snow Blade, Landscape Rake, Ballast Box, PHD, The Wife
  7. #7
    Join Date
    Mar 2008
    Posts
    1,499
    Maine
    Deere 3520 Cab, Deere F935
    Quote Originally Posted by Hillstone View Post
    In PA I would have used Low-Vis HyGard...its whats reccomended for pretty much everywhere except where snow never hits the ground....
  8. #8
    Veteran Member Runner's Avatar
    Join Date
    May 2007
    Posts
    1,682
    Missouri
    John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
    According to the manual, regular Hygard is good down to about 0 degrees and it doesn't get that cold around here (Kansas City) very often. If it is that cold, I won't be out messing with the tractor.
    Therefore, I also went with the regular Hygard oil.
    Wish you could get the red stuff they put in from the factory because it smells nicer :-)
    Runner
  9. #9
    Join Date
    Jul 2006
    Posts
    1,918
    New York
    JD 2320
    Quote Originally Posted by Runner View Post
    Must be nice.
  10. #10
    Gold Member
    Join Date
    Aug 2003
    Posts
    478
    Windber, PA
    ALL J-D's: 955, X595, 6x4 Diesel Gator, CX Compact Gator, 310D Loader/Backhoe (4x4, turbo, extend-a-hoe)
    Quote Originally Posted by Spudland_Dave View Post
    Supposedly, according to the O.M. for my 955, regular HyGard may cause some brake 'squeal' when used at low temps, but, doesn't say anything bad will happen. I used the Low-Vis stuff, 'cause my dealer pretty much insisted. I figure he's seen more of those units than me, so....
    R-WEST
    "live so the preacher doesn't have to tell lies at your funeral"
    955, X595, CX Compact Gator, 6x4 Diesel Gator,
    310D Loader/Backhoe (All J-D's)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
