Willl
Elite Member
Old problem that still seems to effect some members.I'm unable to upload to my member gallery and I am unable to create an album.
Just post them directly into the thread.
Or create a Photobucket or similar acc.
unfortunatelyim about to get on an airplane to Toronta so want be able to measure until Thursday. mine is last years 790. maybe someone else will be able to measure theirs.
Just sitting here killing time and remembered that the outside of my fenders are near the middle of my R1s, see attached pictures. I don't think the fenders on the 790/3005 have ever changed.
With my wheels at their narrow configuration the centerline of the tire is directly beneath the outside edge of the fender. My hope is that if I am able to push the wheels out 4" further on each side (by swapping the rims right to left and left to right) I'd have enough room for chains.
I did notice that my wheels are different than yours. (Mine are 2002.)
Kevin
My experience with 8-position rims on a JD970 lead me to a different conclusion... if you keep the same tread direction and swap the wheels to the opposite side, the "cup" or dish of the rims will give you a narrower wheel stance - not wider.
You will need to unbolt the rims from the center and move the tire/rim to the innermost mounts in order to place the tire out to it's widest stance.
I would certainly get them as wide as possible for stability. Mine came in their widest position.
