Results 1 to 4 of 4
03-25-2009, 10:14 AM #1New Member
- Join Date
- Nov 2006
- Posts
- 4
1989 JD 955 engine
We think the engine is shot. Possibly a bad piston or rings.
Are parts availble to do a rebuild? Might do a compression test to see.
It does run but has a miss and is low on power. Are replacement engine availble or maybe a repower with Kubota engine?
03-25-2009, 02:01 PM #2
Re: 1989 JD 955 engine
Parts should all be available, but to do it right is gonna hurt, If I remember right there are short blocks still in stock, but you will be tying some serious money up in the repair
03-25-2009, 02:41 PM #3Veteran Member
- Join Date
- Feb 2007
- Posts
- 1,265
- Location
- SE Conn
- Tractor
- Kubota L35TLB, "69" Deere 110,'89' Cub Cadet 1541
There could be other reasons for misfiring and lack of power. First do the diagnosis, then do the repair. Yes do a compression test, and if necessary do other tests. Check it over carefully.
contaminated fuel, dirty fuel filter, fuel delivery problem, bad/dirty injector(s), injector pump timing, weak injector pump, timing chain/gear issue, worn/burnt valve(s), blown head gasket(a little coolant getting into a cylinder)etc.(what else am I missing guys?)
How many hours on the engine?
.....Tim
03-25-2009, 02:54 PM #4Elite Member
- Join Date
- Feb 2004
- Posts
- 4,105
- Location
- NorCal
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe
I have rebuilt 3 of those engines, using 0.5mm oversize pistons. A few years
ago, they were a bit over $100/hole for the piston/ring set from JD. If
you have a broken piston, I have some spares if you don't need oversize.
I am about to do a JD4300.
Forget about a new engine from JD, unless you find a 3TNE84RJ in old
stock at a dealer somewhere. I looked for one when I started my first
955 rebuild and I found a dealer who had one....for $5300!
As for replacing the engine with a non-JD, that is a very doable project,
since the 955 has a full frame and no bell housing betw the engine and
tranny. Only a bare drive shaft with no clutch. I considered subbing one
of my bad engines with a gas Honda engine I happen to have. Also, the
955 has its hyd implement pump on the back end, rather than on the engine.See my TBN projects at:
http://mysite.verizon.net/resyfcgt/
