Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Gold Member
    Join Date
    Oct 2000
    Posts
    412
    NH
    John Deere 3720 Cab Tractor
    Default 3rd Function Hydraulic Coupler Bracket
    Is it possible if as many of you guys can, can post a picture of the bracket that holds the 2 couplers on for the 3rd function hydraulics... I've had trouble with my loader hoses since day one.. and of course I kept trying to tell my dealer that he is wrong on how they are mounted. Because I can't get my loader hoses to plug in to the couplers withe the 90 degree elbow pointing up, with the bracket mounted the way it is.. I think my 3rd function bracket is upside down... they think not.....
    it has to be specifically a 3000 TWENTY CAB MACHINE!
    Please help me fix this problem once and for all.... he has my machine there right now, and says it can't be done the way I think it needs to be done, because of the A/C hoses in the way etc..... I know I've seen it done the other way... and he thinks I'm crazy...
    as of right now, only one of my loader hoses can plug in with the elbow pointing up, like it should... because of the 3rd function hydraulic bracket is in the way...
    I need many pictures to prove how it is to be done..... just one machine won't do... I guess he wants many pics....
    thanks Jason
  2. #2
    Super Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
    Default Re: 3rd Function Hydraulic Coupler Bracket
    Jason - how about posting a pic or two of your loader 3rd function mount?
    Other users could benefit by understanding your problem better -- and owner's of 3000 series machines with the FEL SCV could also see immediately what the likely issue might be.
    I would also believe that the design for the 300CX loader SCV mount is not that different from the 4000 series loaders; 400X and the 400CX.
    Heck, it probably isn't that much different than the mounting configuration for my JD 110 TLB.
    Let's see what's ya got...
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
  3. #3
    Gold Member
    Join Date
    Oct 2000
    Posts
    412
    NH
    Hi Akfish,
    I would take a picture of my couplers but my machine is in the shop which is quite a ways away from me right now.
    Yes, the 4000 series and the 3000 series are very different...
    Also yes, it has to be the cab version pictures I show him because of clearance issues with the glass, and the radiator/Heat and A/C hoses... also the mounting posts the loader sits on are different than the open station tractors....
    I need pictures of anyone who has Auxillary 3rd function hydraulics, to show me some pictures of how there 2 extra couplers are mounted in relation to the 4 primary loader hose couplers... I think my bracket is on upside down, because there is no clearance for my regular hoses to plug in the way they are supposed to.... 90degree elbows pointing up is the correct way..... see mine have to point down the because of interference with the 3rd function bracket..... so yes, must be a 3000 Twenty Cab machine...
    thanks..
    Jason
  4. #4
    Join Date
    Mar 2008
    Posts
    1,499
    Maine
    Deere 3520 Cab, Deere F935
    Send me $300 and change and I'll order it up, install it and send you pics...
    On a serious note, I'm anxious to see pics myself...I've been planning on getting it eventually for my 3520 Cab/300cx....
  5. #5
    Silver Member GreenMtns's Avatar
    Join Date
    Oct 2006
    Posts
    246
    Western Vermont
    Kubota B2601
    Quote Originally Posted by JasonMac View Post
    thanks Jason
    Hi Jason
    Best I can do for you since I replaced the 3rd function bracket with the bracket for the diverter system on the right so I can plug the grapple lines into it without having to deal with loose lines when it was not needed. However the 3rd SVC bracket looked just like it but was narrower and only had one set of lines coming out of it.
    Look in JDparts and there will be a diagram of the mounting for the 3rd SVC bracket. I have also attached a picture from the JDParts page to show you how it should mount.
    Hope this helps.
    Attached Thumbnails Attached Thumbnails 3rd Function Hydraulic Coupler Bracket-3rd-svc-gif
    Al
    Kubota B2601, 5' King Kutter rear finish mower, 4' King Kutter rototiller, 4' Frontier rotary mower, Lienbeck Cultivator, 5' box blade, Land Pride Grapple, Land Pride snow blower, Land Pride pallet forks.
  6. #6
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,964
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Quote Originally Posted by GreenMtns View Post
    Hi Jason
    Hope this helps.
    he is looking for pictures of the front couplers-where the FEL plugs in.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  7. #7
    Join Date
    Oct 2006
    Posts
    246
    Western Vermont
    Kubota B2601
    Quote Originally Posted by kennyd View Post
    Sorry 'bout that Kenny, when he said 3rd function I thought he meant the SVC. The loader hoses should be set up to to connect coming from the top not the bottom, as in the attached picture. When I received mine it was put together wrong and I had a heck of a time trying to get hooked up. I finally found the instructions in the loader manual.
    Just caught my mistake again. Back to the barn for another pict. Will post it ASAP
    Attached Thumbnails Attached Thumbnails 3rd Function Hydraulic Coupler Bracket-100_0348-jpg
    Last edited by GreenMtns; 04-19-2009 at 08:10 PM. Reason: Reread the post and he wants the top two hoses as well
    Al
  8. #8
    Join Date
    Oct 2006
    Posts
    246
    Western Vermont
    Kubota B2601
    Here are two pictures of the connection of the 3rd function hoses. One from the back and one from the front. The one from the back is through the cab glass so it looks a little green. As you can see there are no 90 degree elbows in the lines. By the way, the bracket angles up from the points where it bolts onto the loader mast.
    It sure sounds like the bracket is installed wrong. The 3rd function hoses should be well above the loader hoses and there is no interference at all. I installed the kit myself following the excellent directions that came with the kit. It could be easy to mix it up IF you don't read the directions and "think you know how it is done"
    Attached Thumbnails Attached Thumbnails 3rd Function Hydraulic Coupler Bracket-100_0351-jpg   3rd Function Hydraulic Coupler Bracket-100_0352-jpg
    Al
  9. #9
    Gold Member
    Join Date
    Oct 2000
    Posts
    412
    NH
    Thank you GreenMtns! This is exactly the way I am trying to explain it to the service manager at the dealership that I deal with....
    they had my bracket on upside down, opposite of yours... see how yours points UP and out of the way of the 4 lower couplers? They had mine pointing down, in the way of the lower couplers and kept telling me that is the way it is supposed to be.... I knew it wasn't supposed to be like that, because I couldn't plug in my regular loader hoses with the elbows pointing up with it the other way...
    thank you very much....
    I've emailed them your pictures for proof that I'm not crazy...
  10. #10
    Join Date
    May 2008
    Posts
    1,304
    Eastern Ia
    JD 4310 eHydro,
    I'll bet the service managers hate the internet!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
