Karl2
Gold Member
I was driving my tractor down my driveway with garbage bags in the bucket, I stopped and hopped out at the end of the driveway to throw the trash in the bin when all of a sudden my tractor just stopped. It stopped the same way it does when I inadvertently get off the seat while PTO is engaged. But it didn't stop as soon as I left the cab, I had been out a good 30 seconds when it died.
At first I thought I had inadvertently pulled the PTO knob while getting out but when I went back to the cab and checked the knob was down. Tried starting it but no go, not even a click. Battery is fine, all the lights burn bright and electrical equipment works as it should. However I get a "PTO on" message when I try to start and two of the three PTO indicators are lit. That's right, two indicators are lit one saying 540 rpm and the other 2000 (approx. figures) so obviously the reason the tractor won't start is because it "thinks" a (or two) PTO(s) is/are engaged.
Problem is, I only have one PTO (rear) on this tractor and I'm quite sure it can't run at two different speeds at once. And besides, it is not turned on and there is currently no attachment to the rear PTO. Up until today the tractor ran fine.
If only I could clear this error I know it would start but I have no idea how to reset this
Any ideas?
Thanks in advance!
Any ideas?
Thanks in advance!
