Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Apr 2009
    Posts
    11
    John Deere 4310
    Default 4310 leak (help)
    Noticed my tractor has fluid on the tractor side of tire. Looks like it may be coming out where the wheel hooks to the drive shaft. Any help would be greatly appreciated.
  2. #2
    Elite Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    4,882
    Kasilof, Alaska
    JD 5075M; JD 110 TLB; Ford Ferguson 9N: JD X300R
    Default Re: 4310 leak (help)
    Sounds like a leaky axle seal. If it's just a drip now and then - you could likely live with it for a spell - and your tractor won't suffer undue harm - IMO.
    Worked around a fair number of older, Ag machines and a few of them had axle seals that were tired and worn - so, there was always bit of gear lube on the floor every morning.
    The repair looks to be reasonably difficult - here is a part's diagram - John Deere - Parts Catalog
    And, likely will require that you take it to a dealer or an experienced tractor repair shop.
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
  3. #3
    New Member
    Join Date
    Apr 2009
    Posts
    11
    John Deere 4310
    Its leaking pretty good. How much am I looking at getting it fixed??
  4. #4
    Join Date
    May 2008
    Posts
    847
    Eastern Ia
    JD 4310 eHydro, JD 322
    Here is a how to in the old posts
    http://www.tractorbynet.com/forums/j...ront-axle.html
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
