Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > John Deere > John Deere Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 05-20-2009, 08:48 AM   #11 (permalink)
New Member
Default Re: 4wd on 4310 won't disengage
Actually the two wires that come from the selenoid are black and they do not appear to have numbers on them. They are not red, purple or white like some of the other wires throughout the tractor. There is no black protective plastic around them. There may have been at one time. This is the original selenoid.
mdfarina is offline   Reply With Quote
Old 05-20-2009, 03:00 PM   #12 (permalink)
gbw
Member
Might be worth a try...my '06 (180hr) 4320 gets cranky about this now and then, I raise the front wheels off the ground an inch with the fel and it slips into and out of 4wd easily.
gbw is offline   Reply With Quote
Old 05-20-2009, 11:59 PM   #13 (permalink)
Gold Member
I will have to go out and crawl under the tractor and see what mine are. What did you find on fuse f-5??
mfreund is offline   Reply With Quote
Old 11-03-2009, 11:51 AM   #14 (permalink)
New Member
Ok to follow up on this....It turns out that the little pins in the connector were not seating fully. This is the connector at the selenoid. When I was installing my front pto kit and had the rear wheel off, was able to really get at the connector and selenoid. I took the connector apart and after cleaning and reseating the little pins inside the connector the 4wd worked fine. Must have really gotten ripped by a branch or something.
Old 11-03-2009, 11:53 AM   #15 (permalink)
New Member
Thanks for all the help...this has over 500 hits. I might add the 4310 is a tuff little tractor.
Old 11-03-2009, 10:32 PM   #16 (permalink)
Gold Member
It seems like that is a common problem, I should make sure all the wires are "high and tight" on mine!!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.18868 seconds with 8 queries
