Shimon
I'm working on an old reverse rotation JD 6404 engine (flywheel spins CW). The rear main seals that JD has available are all for normal rotation engines and they are directional so I can't use them in this engine. JD no longer carries the reverse rotation seals. I've got some feelers out with some bearing houses so see if they can come up with a sleeve/lip seal for this engine. This is a stab in the dark but was wondering if anyone has any leads.
