Results 1 to 9 of 9
  1. #1
    Silver Member Dale1995's Avatar
    Join Date
    Jul 2008
    Posts
    163
    Caribou,Maine
    John Deere 2320
    Default Recommendations for Front mount snowblower Chain Lube?
    I have been servicing my tractor and snowblower for the upcoming snow season! I'm wondering what everyone is using on their chains to keep them lubed up. It would seem that something that is thick and stringy would work best, I had purchased some chain lube but found that its very thin, almost like WD40.... so don't know what to use. What are you guys finding that works well for you and doesn't make a big mess of everything.
  2. #2
    Gold Member
    Join Date
    Apr 2008
    Posts
    269
    Bigfork, Mn.
    JD 4110HST
    Default Re: Recommendations for Front mount snowblower Chain Lube?
    When I had a chain drive snowblower, I used the Polaris chain lube that I had for my four wheeler. Worked great.
  3. #3
    Elite Member ToadHill's Avatar
    Join Date
    Oct 2005
    Posts
    2,711
    Catt county New York
    Kioti DK35, Ford 8N, Oliver Cletrac
    I just go to the local motorcycle shop and get spray on chain lub from them. The cycle chain moves a lot faster than the blower chain and if the lub will stay on it, it will work well on the blower.
    I can't control my day but I can control my attitude.
  4. #4
    Gold Member themichelob's Avatar
    Join Date
    Apr 2004
    Posts
    273
    Eastern Washington
    Kubota B7800
    I've been using 30wt motor oil in a pump oil can on mine for the last five years. Seems to lubricate quite well, and in cold conditions it dosen't run too much so not much mess. I don't know if there's any downside to this, but it works for me. Regards, Mike
  5. #5
    Elite Member irvingj's Avatar
    Join Date
    Feb 2008
    Posts
    2,766
    Etna, NH
    2007 MF GC2310 TLB
    Ditto Toad Hill!
    I've had good luck with Honda "HP" chain lube; it drips a bit, but not very darned much- I just put a piece of cardboard under the chain section of blower to keep any drips off concrete floor.
    Attached Thumbnails Attached Thumbnails Recommendations for Front mount snowblower Chain Lube?-honda-chain-lube-jpg
    '07 GC2310 TLB, 2360 snowblower, 2325 MMM, Bro-Tek thumb, Woods GTC40-2 tiller, Woods RB-60 back blade, DR 60" Power Grader, DR Lawn & Leaf Vac
    '05 VW Jetta Wgn TDI
    Numerous vintage Japanese motorcycles
  6. #6
    Join Date
    Mar 2008
    Posts
    1,499
    Maine
    Deere 3520 Cab, Deere F935
    I used the JD Chain & Cable lube...sprays a foamy oil which coats the chain nicely...
  7. #7
    Join Date
    Mar 2008
    Posts
    79
    S E Mass.
    STP makes a decent stay put lubricant. Works good on sleeve bushings.
    I use it anywhere white lube is recommended. White lube will be long gone before the STP is.
  8. #8
    Join Date
    Sep 2008
    Posts
    67
    Sask Canada
    Still Deciding
    Quote Originally Posted by Spudland_Dave View Post
    Ditto,
    I use it on my Allied 50" blower and the Gator as well.
  9. #9
    Gold Member
    Join Date
    Aug 2003
    Posts
    478
    Windber, PA
    ALL J-D's: 955, X595, 6x4 Diesel Gator, CX Compact Gator, 310D Loader/Backhoe (4x4, turbo, extend-a-hoe)
    Another vote for that one. Really seems to hang on there..
    R-WEST
    "live so the preacher doesn't have to tell lies at your funeral"
    955, X595, CX Compact Gator, 6x4 Diesel Gator,
    310D Loader/Backhoe (All J-D's)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
