Go Back   TractorByNet.com > John Deere > John Deere Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-31-2009, 10:22 PM   #1 (permalink)
Member
Default 47" snowblower 2nd stage position bolts
has anyone changed the (2) allen bolts to #8 bolts to allow for easier maint. and positioning of the 2nd stage auger on the rotating shaft
My allens were always coming loose
I switched to #8 bolts and lock washers for this season
tkoza is offline   Reply With Quote
Old 11-02-2009, 12:08 PM   #2 (permalink)
Default Re: 47" snowblower 2nd stage position bolts
We've used locktite there before.
we have also used some 1' split
locking collars to prevent the auger
from sliding forward and interfering with
the housing.
i would think they would redesign that,
or at least put the set screw on the key.
we have made impressions in the shaft for
the set screws also.
Dutch445 is offline   Reply With Quote
Old 11-03-2009, 12:25 AM   #3 (permalink)
Member
dutch 455
what did you use to indent the shafts???
i plan to disassemble the unit next spring and send it out for power coat
overall not bad from a unit i purchased in 1993
Old 11-03-2009, 08:32 AM   #4 (permalink)
I think we just ground down a little
bit of a flat spot, that the set screw
could bite better, and it gave it a lip
that it couldn't slide forward so easy
Old 11-04-2009, 10:20 AM   #5 (permalink)
Gold Member
chipsndust's Avatar
Dutch / tkoza:
Are you guys talking about the set screws in this pic?
Or are you talking about the other end of the shaft with the impeller on it?
You can see in this pic that one of the set screws is on the key, but the screws have square heads.
I'll have to check the front end on mine.
chipsndust is offline   Reply With Quote
Old 11-04-2009, 04:24 PM   #6 (permalink)
I'm referring to the allen screws in front of
the Impellar, they have a tendency to come
loose and let the impellar slide forward on the
shaft.
Old 11-04-2009, 07:13 PM   #7 (permalink)
Member
c&d
correct the set screws on the front
what year is the unit in the pic?
as the square head bolts could be an answer
tkoza
Old 11-04-2009, 11:30 PM   #8 (permalink)
Gold Member
chipsndust's Avatar
Thanks guys.
I posted in another thread about the gear in the pic moving on the shaft. Since the gear on the rear of the shaft shifted, I need to check the set screws in the front.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Page generated in 0.05332 seconds with 9 queries
