Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > John Deere > John Deere Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-01-2009, 11:49 AM   #1 (permalink)
New Member
fdmars's Avatar
Default 2305 or similar sized and the northern tool 3pt 13 ton log splitter
thinking of getting the northern tool 13 ton logsplitter for a jd 2305 and a jd 4115, has anyone had any experience or comments on this set up?
Thanks Fred
fdmars is offline   Reply With Quote
Old 11-01-2009, 11:52 AM   #2 (permalink)
Super Member
kennyd's Avatar
Default Re: 2305 or similar sized and the northern tool 3pt 13 ton log splitter
It will work, but will be very slow. The 4115 only has a 5.1 GPM pump, and the 2305 only 2.9 GPM is available to the implements.
__________________
JD 4110HST
FEL, 60" MMM, 60" Rear Blade, Ballast Box, I-Match, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, Markham LD-48 Grapple and much more "stuff"
JD 4x2 Turf Gator
Some of my projects/adventures are posted in my Picassa Web album.
kennyd is offline   Reply With Quote
Old 11-01-2009, 12:11 PM   #3 (permalink)
New Member
fdmars's Avatar
thanks for the info Ken, do they make a kit to divert flow from the steering to the implements? or is 2.9 GPM all you get period.
Old 11-01-2009, 12:17 PM   #4 (permalink)
Super Member
kennyd's Avatar
Quote:
Nope, 2.9 is it...and that will be at around the rated PTO RPM.
__________________
JD 4110HST
JD 4x2 Turf Gator
Old 11-01-2009, 05:14 PM   #5 (permalink)
soulasphil's Avatar
I just got a 13 ton log splitter. I have a JD 3520 that gives 8 gpm for implements. I cannot say it's very fast, but that depends entirely on engine rpms. I run it just above idle and barely have time to collect the split pieces while the ram is going up. Then I must put a new piece of wood under the splitter. So IMHO speed is not really important if you are working by yourself.
2305-similar-sized-northern-tool-dscf1881-r-olution-de-l  2305-similar-sized-northern-tool-dscf1882-r-olution-de-l  2305-similar-sized-northern-tool-dscf1889-r-olution-de-l  2305-similar-sized-northern-tool-dscf1890-r-olution-de-l
__________________
3520 PR
soulasphil is offline   Reply With Quote
Old 11-01-2009, 05:35 PM   #6 (permalink)
Super Member
kennyd's Avatar
Fred...shoulda mentioned earlier: Look HERE for a calculator-just plug in your numbers and you can make a decision.
__________________
JD 4110HST
JD 4x2 Turf Gator
Old 11-01-2009, 08:44 PM   #7 (permalink)
New Member
fdmars's Avatar
Thanks for the info. I will look at it
Old 11-02-2009, 03:42 PM   #8 (permalink)
Send a message via Yahoo to orlo
Just a suggestion. If you get a two directional splitter (A Splitfire) you can split
on both strokes. It'll make the most of low GPM flow.
I have one and have run it on a 3720 and have hookups on my 2305 although I've never run it on the 2305. At just above idle I cannot keep up with it splitting in both directions due to having to get rid of the wood.
Split-Fire Sales Inc. :: Welcome :: Quality Built. High Performance. Split-Fire - Your Best Choice
__________________
"I'd rather be on my Tractor"
orlo is offline   Reply With Quote
Old 11-02-2009, 07:24 PM   #9 (permalink)
Look at this thread http://www.tractorbynet.com/forums/m...-splitter.html. I have pics of my set up in there. I don't believe in running a 3pt splitter off the tractor hyd. Use the Prince PTO pump. I am 6sec cycle time and the tractor be idling with great speed on the ram.
wkpoor is offline   Reply With Quote
Old 11-02-2009, 10:21 PM   #10 (permalink)
Gold Member
Splitting wood alone sucks.
I make sure I have a helper, otherwise its just not safe when splitting big pieces, because I split on a horizontal splitter, and the heavy pieces fall on your feet and legs, and then you have to pick them up again. I hate the vertical position, because my back can't handle that for very long at all. The lifting off the ground is horrible for anyones back.
__________________
JD 2520 --- FEL, I-Match, LX4 Rotary Cutter, DR Brush Chipper, Ballast Box, 71 Flex Planter!
Deadman is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.31569 seconds with 9 queries
