Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. #1
    Join Date
    Sep 2009
    Posts
    139
    Maine
    John Deere 4120
    Default iMatch vs Speeco / FarmForce Quick Hitch: Experiences and Opinions?
    We need to buy another quick hitch as it's a pain sharing the one iMatch we have between tractors. Noticed the Speeco Quick Hitch - sold as a FarmForce brand at TSC. The Speeco unit looks beefier than the JD imatch and it has an adjustable top hook. Best of all - it's about $75 cheaper that the iMatch. Anybody have experience with the Speeco's. Would love to hear your opinions. Also - the TSC units are this calf turd yellow color - downright ugly. I know the Speeco units are available in black. Anybody know of a low cost source for them?
    Deere 4120 eHydro, 445 Hydro, 2210 Hydro, 320X Hydro, Kawasaki 3010 Mule. Lots of implements. I'm pretty sure this Deere addiction is a sickness!
  2. #2
    Join Date
    May 2003
    Posts
    160
    Indiana
    Deere 3005
    Default Re: iMatch vs Speeco / FarmForce Quick Hitch: Experiences and Opinions?
    Speeco makes a couple different ones. There are two listed as Cat 1 hitches that have different spacing between the lift arms (One having a spacing of about 26 1/2", the other being about 27" or 27 1/2 "). I would be sure to measure your implements before going to TSC, and then measure the hitches when you are at the store.
    As for a low cost source, you might try Rural King or Harbour Freight.
  3. #3
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,924
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    My vote is the I-Match. It's the right quality and the right color. The adjustable top hook on the Chinese knock-offs mean nothing to me-if I have to get off to change it then it's not a QH to me. All of my implements are either bought I-Match compatible or made that way by me.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  4. #4
    Join Date
    Jul 2006
    Posts
    1,084
    WI
    John Deere 2520, X475
    ^^^^^^^^^^^^^^ exactely. I Match
    JD 2520 --- FEL, I-Match, Frontier RC2460 Rotary Cutter, Pallet Forks, DR Brush Chipper, JD Ballast Box, 71 Flex Planter!
  5. #5
    Elite Member CurlyDave's Avatar
    Join Date
    Dec 2005
    Posts
    4,480
    Grants Pass, OR
    JD TLB 110
    If I already had one iMatch, I would get a second just to be certain everything was completely compatible.
    You could have more than $75 worth of headache with just a minor misfit.
    40 Acres on a hill - fantastic view. JD 110 TLB, 4-n-1, 12" bucket, 18" bucket, Addington thumb, rock bucket (doubles as root grapple)
    Not only do we not understand the universe, if someone explained it to us, we would not know what he was talking about.
    Isaac Asimov
  6. #6
    Join Date
    Apr 2005
    Posts
    134
    Central Wi
    JD 4110, X500
    Bought the Speedco with the tractor 7 years ago. The difference in price more than paid for the chain boxes and a quart of JD Green to made it the "correct color".
    Only instance where the adjustable hook came into play is when I had to attach an older brush hog at a neighbors. The H adapter that came with the hitch allowed the use of that non-I match compliant cutter without dropping the quick hitch. Of course the hook had to be removed, which probably took about as much time as dropping the entire quick hitch (at least with two people around that is. If it were only me, using the H adapter would have been quicker---and easier on the back-- than wrestling the QH alone).
    Good luck.
    Attached Images Attached Images
  7. #7
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,767
    Upper Midwest USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    X 3
    I Match
  8. #8
    Join Date
    Sep 2009
    Posts
    139
    Maine
    John Deere 4120
    New twist: I think I'm going to convert to Pat's easy change system. I'll leave the iMatch on the 2210 and use Pat's system on the 4120. Most implements won't be shared going forward anyway and I really like the flexibility of the Pat's system. Allows any Cat 1 implement to be sued without bushings - including my PHD.
  9. #9
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,424
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    I would go with I Match on everything KISS. You never know when you will need to use the other tractor with an implement even if it is just to move it out of the way. I dont see where Pat's easy change is as easy as I Match.
    Steve
  10. #10
    New Member
    Join Date
    Jun 2009
    Posts
    6
    JD 3320, Ferguson TO30
    Pat's is not made to be as easy as an I Match. It is made to be more versatile. Since it only does the lower links it will fit any implment with no modification. It will even do a PHD; the I Match, Speeco, and othe quick hitches will not. Pat's should still be easier than hooking up the lower links by hand (although I have never tried adjustable links).
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
