Results 1 to 9 of 9
  1. #1
    Join Date
    Nov 2009
    Posts
    105
    Linn, MO.
    John Deere 4520
    Default 4520 john deere power steering noise
    Has anyone figured out why the John deere 4520 power steering makes the wining noise. I have been thinking of tearing into mine and having a look. I am new to the forum so if this has been discussed I am sorry.
  2. #2
    Gold Member
    Join Date
    Oct 2007
    Posts
    340
    North Central Mississippi
    JD 4320
    Default Re: 4520 john deere power steering noise
    I have noticed some noise with my 4320 also. However, I do not know the cause
  3. #3
    Super Member
    Join Date
    Feb 2008
    Posts
    7,747
    somewhere usa
    stuff
    I haven't heard any steering whine noise so far on my 4520. Do you still have warranty?
    Steve
  4. #4
    Platinum Member eepete's Avatar
    Join Date
    Sep 2009
    Posts
    962
    Efland, NC
    JD 4520, Kubota B21, JD 318
    I hear a very faint whine, which I am assuming is hydraulic servo noise. It's similar to the noise you can hear sometimes when you push the pedal to go faster. Note that I can't hear the noise unless I have my hearing protection on and that's in a cab tractor.
    Related comment: I have squeaking in my cab. Tried lubricating the door seals, no luck. Dealer comes out next week to look at it, will ask about the slight steering and acceleration whine.
    Pete
    '09 JD4520 Cab (60HP), '97 KubotaB21 TLB (21HP), MX6 rotary mower, SB1106 6' Sickle Bar, BB3272 6' box blade, GradeMaster 7' Landplane, 6' landscape rake, Woods GTC 40" tiller, PHD 9" auger, 4' x 8' chain harrow, '90 JD318 (18HP gas) with 48" MM mower, 54" front blade, 47" snowblower.
    Volunteer Firefighter.
  5. #5
    Join Date
    Aug 2004
    Posts
    61
    Southwestern PA
    Kubota B7610, John Deere 4520
    I've read about this before and can say that I've only heard a slight whine on my tractor once - when I was turning and had the wheels at full lock to one side. Then again, I only have about 35 hours on my tractor.
  6. #6
    Join Date
    Oct 2004
    Posts
    59
    Western Michigan
    John Deere 4320
    Do a search for "steering" in the John deere section. I and a few others have the same issue.
  7. #7
    Join Date
    Mar 2009
    Posts
    145
    Arkansas
    John Deere 4120
    My 4120 whines like crazy. I just figured it was because these things have two hyd pumps, one is just for the steering. I bought mine used and I have about 300 hours on it now. It's always been loud.
  8. #8
    Join Date
    Sep 2009
    Posts
    962
    Efland, NC
    Follow up: My JD dealer was out this morning. The squeak was in the steering wheel. Took wheel off, took boot off, clean and lubed up the shaft and a white plastic bushing. Squeak is gone. The noise I had sometimes when I turned the wheel is also gone. Don't know if that's the noise being referred to in this thread. Dealer agreed that the squeak would drive you crazy if you had to hear it all day. I told him if it drove me crazy it would be a quick trip to a familiar location.
    I still hear both hydraulic and servo whine, particularly when wheels are turning hard or at the end limit but it's very faint and in the background. Sometimes listening in the cab with and without hearing protection lets you hear different things. It's not objectionable and is consistent with all the other little noise you hear. You get used to them, and it's part of the feel of the tractor and it's how you can tell if something is wrong.
    I'm real happy with my JD dealer. The quality of the dealership was my 1st, 2nd, and 3rd factors influencing what I bought. There are good and bad dealers of all colors spread around the planet, and I'm lucky to have a good one near by. I've also bought almost all of my implements from him so we have a good relationship and he can stay in business. I'll pay a bit more to have just one company that I deal with that is making sufficient margins that it can own and solve my problems. The day tractor dealerships and tractor owners start treating each other as if it were the Wall Mart experiance we're all screwed.
    Pete
  9. #9
    Gold Member
    Join Date
    Nov 2008
    Posts
    403
    Maine
    '09 JD 5105M Cab & '05 JD 4720 Cab
    Quote Originally Posted by CrownHawg View Post
    My 4720 is also a whiner, both steering and accelerating in MFWD mode which is practically always on since I only use this tractor for snow removal. It's been this way since I had it and I'm told it's normal. I only hear it at low rpm.
    JD 5105M & JD 4720 Cabbies w. Shoule reversible snow blade/Shoule rear snowblower; Pronovost blower; backhoe and some attachments I have no idea what they are for.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
