Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    New Member
    Join Date
    Jan 2010
    Posts
    7
    Default Re: 2305 Curtis Cab Install
    Yes, I did mean getting in and out of. The salesman was a woman and she said I had a "little tractor"! I've never been told I have a little tractor.
  2. #12
    Join Date
    Sep 2008
    Posts
    64
    Rochester, NY
    Rest of the pics attached.
    Last one (lower radiator hose) added, by request. I actually skipped this intentionally as I don't like the way it turned out, blocking the oil fill. This is how I interpreted the instructions, but I plan to get another lower radiator hose and try it in the bottom straight (vertical) section when it's time to do a radiator flush in a year or so.
    Attached Thumbnails Attached Thumbnails 2305 Curtis Cab Install-dsc_9593-copy-jpg   2305 Curtis Cab Install-dsc_9594-copy-jpg   2305 Curtis Cab Install-dsc_9595-copy-jpg   2305 Curtis Cab Install-dsc_9596-copy-jpg   2305 Curtis Cab Install-dsc_9597-copy-jpg
    2305 Curtis Cab Install-dsc_9599-copy-jpg
  3. #13
    Platinum Member etcallhome's Avatar
    Join Date
    Mar 2005
    Posts
    655
    WV,Preston County
    JD 1026R
    Just wondering , seen your photos of heater hose connections
    Do you have a photo of the lower radiator hose connection ???
    If so thanks in advance.
    Have fun and be safe !!!
    JD1026R H120 fel w/54"bucket; 60" mmm ; 260 BH/w 12" bucket; ballast box; rear weights; front quick hitch w/angling kit and 54 " blade ;3pt rear 60" blade ; JD 47" frt snowblower ; Original Tractor Cab;Bush Hog 47" tiller and 15" Middle Buster
  4. #14
    New Member
    Join Date
    Jan 2009
    Posts
    7
    Spokane, Washington
    John Deere 2520
    Diz,
    My John Deere dealer gave me a good suggestion about the heater hose shut off valve.
    He said to mount it under the heater in the cab so that you can control the amount of water/heat coming into the cab. Also, it's a lot easy to get to when you want to shut it off or turn in on.
    Did you have any problems with leaks with the adapter for the top heater hose?
    msturbo
  5. #15
    Join Date
    Sep 2008
    Posts
    64
    Rochester, NY
    That's a good idea, plenty of room there too, I'd think.
    I did have leaking in the fitting attached to the thermostat housing. Couldn't tighten it down anymore as it was hitting the temp sender, so I just added a layer of teflon tape. Hopefully that'll hold. That fitting was easily 50% of the time it took me to do the whole heater.
  6. #16
    Gold Member Labrat's Avatar
    Join Date
    Mar 2004
    Posts
    268
    Central NY
    JD 2210
    I didn't install the shut off valve on mine. if you close the valve there is no coolant flow passing by the temp sender for the temp light so if the engine over heats it may be to late by time the light comes on if it even does.
  7. #17
    Member t man's Avatar
    Join Date
    Nov 2008
    Posts
    32
    northern vermont
    john deere 2320
    Quote Originally Posted by msturbo View Post
    Diz,
    msturbo
    I found this valve and installed it instead of the one curtis gives you.Heater Valves & Cables I also ordered the cable made a bracket and mounted it on the side of the heater.Now it is as easy as pulling a lever to control the amount of heat.Here are some pics of it.
    Tim
    Attached Thumbnails Attached Thumbnails 2305 Curtis Cab Install-000_0203-medium-jpg   2305 Curtis Cab Install-000_0204-medium-jpg   2305 Curtis Cab Install-000_0205-medium-jpg   2305 Curtis Cab Install-000_0206-medium-jpg
  8. #18
    Platinum Member glc24's Avatar
    Join Date
    Dec 2009
    Posts
    896
    Southwestern, Pa.
    Very nice installation!!
    Plowing snow in a tee shirt and tennis shoes.........yeah that's the ticket
    Greg
  9. #19
    Join Date
    Sep 2008
    Posts
    64
    Rochester, NY
    Good point Labrat!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
