Results 31 to 40 of 41
06-10-2010, 01:23 PM #31Bronze Member
- Join Date
- Mar 2009
- Posts
- 64
- Location
- IN
- Tractor
- John Deer 2520
Re: SE SEAT FOR MY 2520
The pics.
Last edited by RRILEY; 06-10-2010 at 01:37 PM. Reason: still having problem no pics
06-11-2010, 09:08 PM #32
Hello RRiley
Looking real good
It looks like you used the same brackets as I did. Were you able to just purchase what you needed,or did you have to get the attaching parts kit?
Greg2009 2520
FEL/61" HD bucket/replaceable cutting edge
62D2 MMM
IMatch Quick Hitch
Homemade 3PT Receiver
Homemade Ballast Box
Woods GB65 Box Blade
A "REAL" snow blade --- JD 380A
90% Restored 1987 JD 316
MY BALLAST BOX:
http://www.tractorbynet.com/forums/b...box-build.html
MY SE SEAT 2520 MOD:
http://www.tractorbynet.com/forums/j...my-2520-a.html
06-12-2010, 04:20 PM #33Bronze Member
- Join Date
- Mar 2009
- Posts
- 64
- Location
- IN
- Tractor
- John Deer 2520
glc24 I was able to purchase the parts separate but about $40.00 each plus.
04-24-2011, 01:55 PM #34
Just a little update:
I thought I would add a few more pics for those with the 23 and 2520.
The way I did my install,still utilizes the factory slider and pivot mount.
The two brackets that are bolted to the seat are from JDs' attaching parts kit. I know someone posted that you can get those separately instead of having to purchase the whole kit. The two rails are M148651 and M148647 (Thanks PCABE5
)They aren't cheap (I think 70.00),but then what is from John deere. The two mods I had to do was slot the seat mounting hole,as it was not inward enough,and cut out part of the bracket where it sat on the back of the slider frame where the factory snubbers used to be.
The seat does slide back as far as possible,but there again the back is alot more meatier too,so it won't go quite as far as factory.
As for the seat sitting higher on the tractor,there is no way around this.As you can tell,it is much thicker (cross section wise) than the factory seat. If you look at the top of the seat back in relation to the hazard lights,the factory seat is 1/3 maybe halfway up the light assembly,where the suspension seat is at the top of the light. If you are a large person,it may be difficult getting in and out of the seat,but IMO,it still can be done.
Is this seat worth an effort to install? You betcha it is! My opinion of course.2009 2520
62D2 MMM
IMatch Quick Hitch
MY BALLAST BOX:
04-24-2011, 02:51 PM #35
I must say this is a very good write-up on how to do this. I installed the seat on my old 2320 the exact same way as on this thread and swapping this seat to my new 2520 was the first mod I did. Great pictures and details on how this can be done.
Once I sit on the seat some of the height difference goes away as the suspension goes down (maybe to much Easter ham). Just to note that fore and aft travel is more limited on the 2520 than the 2320 with this seat.
These instructions should be a sticky for others to follow as they are dead on.2011 JD 2520 | 72" MMM | 200CX FEL 73" bucket | JD 54" Fr Blade | Michigan Suspension Seat | SpeeCo Q-Hitch | JD Ballast-Box | 5ft King Kutter Brush Cutter |
05-17-2011, 08:34 PM #36Bronze Member
- Join Date
- May 2011
- Posts
- 62
- Tractor
- 2010 John Deere 2520
What does SE stand for?
05-17-2011, 08:40 PM #37John Deere 4110HST
FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
John Deere 4x2 Turf Gator
View some of my projects/adventures in my Picasa Album
Simple JDParts Tutorial HERE
05-17-2011, 10:11 PM #38Bronze Member
- Join Date
- May 2011
- Posts
- 62
- Tractor
Im feelin pretty stupid, thanks just the same
05-18-2011, 06:38 AM #39
11-05-2011, 12:18 AM #40New Member
- Join Date
- Nov 2011
- Posts
- 1
- Tractor
- John Deere 2520
I purchased the Michigan seat from ebay for $200. Yea its black, and yea it was less than half the price of the SE yellow seat JD sells. Boy is it worth it whatever the cost!
I mounted mine different than all the other posts I've read about. I simply took the pivoting piece that attaches to the OEM sliding frame, drilled a new 'lower' hole set for the horizontal bar to go through and welded it to the Michigan seat. No need for special attaching kit or seat plate fabrications, use what you already have. Took two hours, and only that long because my welder needs a new tip.
I also cut all but one round off the foam bushings in back to make the seat more level.
I'll get pictures tomorrow.
Similar Threads
2520 suspension seat?????
By Deadman in forum John Deere Owning/OperatingReplies: 51Last Post: 08-10-2011, 12:18 PM -
What's the deal with the 2520 seat? feedback please
By Qhorse in forum John Deere Buying/PricingReplies: 4Last Post: 03-17-2008, 04:03 PM -
Backhoe 2305 rotating seat for backhoe work
By raykos in forum John Deere Owning/OperatingReplies: 2Last Post: 03-16-2008, 08:15 PM -
2520 first impressions vs 2210
By bheston in forum John Deere Buying/PricingReplies: 8Last Post: 07-28-2007, 06:58 AM -
Suspension Seat for B7500
By chim in forum Kubota Owning/OperatingReplies: 3Last Post: 05-10-2004, 12:27 AM
