Cut a bit of firewood this weekend
   / Cut a bit of firewood this weekend #1
KennedyDiesel
Central WI
Here's some pics of my rig. The snow came in and drove me out but I did manage to get one rack (1/2 cord) filled with yellow birch and also pulled down a leaner that I had created. The idea behind my concept is to handle the wood once. Cut split and stack. Strap down to keep secure and take it on home. Once home I have caster boats that pin onto the fork pockets. I wheel; into the basement and carry up top the fireplace as needed.
   / Cut a bit of firewood this weekend #2
What brand and size forks are you using? I'm thinking of getting a set for my 3520. It seems like the frontiers are very heavy for this size machine, any suggestions?
   / Cut a bit of firewood this weekend #3
That is a nice set-up you have there. What a nice outdoor activity. Those pictures looks great with all that snow coming down. Thanks Kennedy for sharing.:)
   / Cut a bit of firewood this weekend #4
Nice set-up! I have used apple crates before, they work great as well. Also apple wharehouses have caster frames you set them on then they can be wheeled around. I bought a bunch at auction, makes packing and moving stuff easier.
Skid steer quick attach and skid steer forks. No they are not light, but they are tough and have a nice headache rack.
Notice the bucket in one pic and the forks in another. I'd hate to fumble with pins out in the snow/woods.
   / Cut a bit of firewood this weekend #6
nice setup, I like to cut wood this time of year, arthritis is slowing me down.
My lower back is questionable many days so when I go I need to get it done. Worst part about working in the snow is there is a middle crust so walking absolutely sucks, Step, support, break through crust repeat...
   / Cut a bit of firewood this weekend #8
Nice setup. Looks like fun, but I know that you get good and wet handling firewood when it is snowing. :)
Do you have pics of the frame for stacking wood?
Might look closer at that idea for handling my unsplit wood from tree tops. Presently place two pallets at the ends and tie them together with 1/4" threaded rod.
Have a lot of used well pipe that I might be able to put to good use too. :)
Now
   / Cut a bit of firewood this weekend #9
Now
yea what he said pictuers please
tom
I'm not sure I follow. Looking for pics of my racks when empty?
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
John Deere 1018 10ft Rotary Cutter (A51573)
John Deere 1018...
2013 John Deere 35D Mini Excavator (A52377)
2013 John Deere...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2019 TAKEUCHI TL12V2 SKID STEER (A51246)
2019 TAKEUCHI...
