Results 1 to 4 of 4
  1. #1
    New Member Sven_SITE's Avatar
    Join Date
    Feb 2010
    Posts
    11
    JD 2320
    Default 2320 PTO shaft for front Hitch- Snowblower
    So i was one step closer to getting my new 47" Snowblower working the last snowstorm until i could NOT get the PTO drive shaft to slip onto the PTO under the tractor for the front hitch/drive. Any ideas? It almost seems as though there is a roller ball catch that needs to push in to engage on the pto but its not? could something be siezed? Am i not alligning something correctly?
  2. #2
    Super Star Member kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    11,125
    Westminster, MD
    John Deere 4110
    Default Re: 2320 PTO shaft for front Hitch- Snowblower
    There is a collar on the driveshaft that needs to be pulled back to disengage the lock-balls. After sliding it on the stub shaft, release the collar and slide back and forth till the balls engage in the groove.
    John Deere 4110HST
    FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
    John Deere 4x2 Turf Gator
    View some of my projects/adventures in my Picasa Album
    Simple JDParts Tutorial HERE
  3. #3
    Join Date
    Feb 2010
    Posts
    11
    JD 2320
    THANKS!! I will try that tonight!
  4. #4
    Platinum Member megotatractor's Avatar
    Join Date
    Feb 2004
    Posts
    963
    New Richland, Minnesota
    JD 2210
    Also try shifting the PTO lever to the rear PTO position which will put the mid-PTO in "neutral" allowing it to turn freely and easily aligning the splines. If the shaft is dry a little WD 40 helps too.
Similar Threads
  1. WTB new or used front mount shaft drive PTO snowblower for Cub Cadet 5264D
    By Sub-Cadet68 in forum Cub Cadet Yanmar & CUTs
    Last Post: 02-13-2010, 12:39 PM
  2. PTO shaft questions
    By RedDirt in forum Build-It Yourself
    Last Post: 12-03-2009, 02:46 AM
  3. Connect PTO shaft using pin or bolt?
    By Richard in forum Parts/Repairs
    Last Post: 11-23-2008, 09:27 AM
  4. PTO, way too often is undervalued in a purchase
    By Keith_B in forum Buying/Pricing/Comparisons
    Last Post: 02-21-2007, 04:16 PM
  5. Bush Hog drive shaft adjustment, Repo
    By BrettFF205D in forum Yanmar
    Last Post: 03-13-2002, 10:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
