Results 1 to 5 of 5
  1. #1
    Bronze Member Acehardly's Avatar
    Join Date
    Nov 2008
    Posts
    76
    Amissville, Va
    L & G 345, X595, 2305, 955 W/FEL
    Default Injector Pump oil
    I have discovered that my injector pump has an oil reservoir. Does anyone know what type of oil goes in there and what indicates that it is full?
    Thanks...
    Tony
  2. #2
    Join Date
    Dec 2001
    Posts
    1,344
    Maryland
    Default Re: Injector Pump oil
    The injection pump reservoir gets it's oil from the crankcase. There is no reason to check or add any oil to it. It is fed automatically from the engine oiling system.
  3. #3
    Join Date
    Nov 2008
    Posts
    76
    Amissville, Va
    Why in tarnation do they put an oil fill cap on this darn thing? They had me all in fluff thinking I hadn't checked one of my fluids....
    Attached Thumbnails Attached Thumbnails Injector Pump oil-injector-pump-oil-cap-jpg
  4. #4
    Super Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
    That's the "lower" crankcase oil filler hole (versus the "upper" filler hole on the valve cover).
    First time I saw that; I had to scratch my head a moment... then I believe someone mentioned that Yanmar configured the engine such that in a marine application or standbye generator or pump use, etc. - the operator could still fill the crankcase in those multiple platforms.
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
  5. #5
    Join Date
    Mar 2008
    Posts
    1,499
    Maine
    Deere 3520 Cab, Deere F935
    You guys use the topside one? Honestly, I never even looked for nor noticed a filler cap on the valve cover...
Similar Threads
  1. How efficient is synthetic motor oil to make.
    By slowrev in forum Oil, Fuel & Lubricants
    Last Post: 10-29-2010, 10:07 PM
  2. Global Warming News
    By KB9UDE in forum Rural Living
    Last Post: 03-11-2010, 09:06 AM
  3. GM Oil Life Monitor
    By Doc_Bob in forum Oil, Fuel & Lubricants
    Last Post: 10-10-2009, 08:15 PM
  4. No Oil Pressure
    By Jim518N381813 in forum General Vintage Tractors
    Last Post: 04-20-2009, 11:28 AM
  5. Slow hydraulics in winter
    By grsr3 in forum Chinese Tractors
    Last Post: 05-02-2007, 12:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
