WorkPorter
- Joined
- May 2, 2009
- Messages
- 7
I'm a newbie with a jd 2305 and a 4' frontier rear mower and have been wrestling over the difficulty of getting the two attached. Eventual success has depended on using 2 variations from standard operating procedure which I've not found discussed in this forum.
#1- Attaching the PTO before the 3 pt. The manual and everyone here (with 1 exception and he drew no replies) says to do the 3 pt hook up first. My problem with this is that hooking up the 3 pt first seems to not leave enough distance for the fully retracted pto drive to line up. In other words the swivel head must be at least slightly tilted away from the tractor's splines when I try to line the two up. To be honest, I've seen a guy from the dealership succeed in making the connection, but it seems he had to do it by coming at it from an angle rather than straight on and I haven't been able to duplicate that magic. I want to know if there's any harm done by my pushing the mower slightly further back (a few inches) from the tractor, attaching the pto, then pushing the mower closer again to hook up the 3 pt connections.
#2- The guy from the dealership warned me of a tight fit in connecting the draft links to the mower. The difficulty here comes from these stabilizer pins. I'm not sure the one pointed to is the exact size I have, but the key feature of these pins I'm referring to are their "usable space". The usable space has to accommodate the draft link, some thickness of steel from the tractor as well as the thickness from the mower. Try as I might to get everything perfectly lined up on both sides there was never quite enough space (off by about 1/8'' on each side) to then insert the lynch pins. So I bought some pins with about 1/4" more usable space and tried to fill in the slack with washers. The washers don't fully take up all the slack. How important is that? The center link I've noticed has a lot of slack built into it with the original parts, but with all the weight of the mower being pulled around would I risk damaging something by not having an absolutely snug tight fit?
Hope my descriptions make enough sense to attract a comment or two.
Thanks for reading this far,
Bob
Bob
