Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Gold Member Kevin M's Avatar
    Join Date
    Nov 2009
    Posts
    356
    goshen NY
    48" bobcat walk behind , 60" Dixie Chopper Classic , 755 John Deere 4x4 70 ldr belly mower etc etc , 7610 Ford 4x4 7412 ldr and 10 ft rhino hogg
    Default 4520 opinions and thoughts
    Im looking to upsize my 1984 ford 1910,4x4, for a good used 2006 john deere 4520 4x4 ,400cx loader , How is this model and what are its issues ? Thanks guys !
  2. #2
    Member EquineNetworkCO's Avatar
    Join Date
    Nov 2009
    Posts
    34
    Larkspur, Colorado
    John Deere 4520 CUT
    Default Re: 4520 opinions and thoughts
    I have a 2008 4520 with 400 CX loader and ehydro tranny. I use it for mostly "utility" type work - grading, snow blowing, moving bales, cleaning paddocks/loafing sheds/stalls, etc. I use it for haying 20 acres in the summer, and I plan to start farming a 10-15 acre plot with it this spring. For those chores, it is superb - lots of power, very maneuverable. The CX loader is very strong. However, if I was going to do more/bigger ag jobs, I'd want a bigger JD - 5E or 5M series. The tractor has been rock solid mechanically (not a single problem), although I'm pretty meticulous when it comes to upkeep. I use JD oil and hydraulic fluid. I figure whats the point in saving a few bucks when I plan to keep the tractor for a long time. The tractor starts easy in cold weather, but I do use a block heater in very cold weather.
  3. #3
    Super Member
    Join Date
    Feb 2008
    Posts
    7,736
    somewhere usa
    stuff
    I have been on the lookout for problems with the 4x20 series tractors for quite a spell and so far these seem to be good tractors. So far I am happy with my 4520, I would think you will have to look at the tractor in question on an individual basis. Look it over for problems and if you have concerns have the local dealer check it out.
  4. #4
    Gold Member Cidertom's Avatar
    Join Date
    Dec 2005
    Posts
    471
    Benton Co Oregon
    JD 4520, 2305 Aktive snow-trac ST4
    Couple of operational issues to consider:
    The CX leveling feature is nice, but... the roll back does not appear to increase as the bucket is raised. This limites the amount of heaped material you can carry.
    The 4520 is outside of SAE cat 1 HP. So some cat 1 implements may not hold up. I buy the cat1 / cat 2 whenever possible.
    JD is serious about the amount of ballast for full 400CX operation. I have been able to pick 2700 lb+ concrete culverts, and with the ballast I was still light on the rear end.
    The JD engine is noisy. Don't try to sneak up on someone with it.
    You will usually break traction before you lose power.
    I love it.
    One of americas vanishing breed: Volunteer Firefighter
  5. #5
    Join Date
    Nov 2009
    Posts
    105
    Linn, MO.
    John Deere 4520
    I owned the 4520 w/loader and backhoe. Power reverser tranny. I had absolutely no problems. The machine has lots of power. I just traded mine for the cab model 4520. If you buy it you will not reqret it. It is like night and day between it and your current ford.. I hope this helps.
  6. #6
    Join Date
    Nov 2009
    Posts
    356
    goshen NY
    Thanks guys I also have a 755 jd and I'm partial to the deere product line , although that 1910 has been a good tractor!
  7. #7
    Member
    Join Date
    Jan 2010
    Posts
    43
    John Deere 4120
    I have the lower horespower 4120 with Power Reverser, 400 CX loader it has been a fine machine, no problems so far, just need more attachments.
    John Deere 4120, 400CX Loader, 73" bucket
    Landpride 2572 Boxblade
  8. #8
    Join Date
    Dec 2004
    Posts
    2,273
    western NC
    JD 2320; 4520
    The 4520 is a fine machine. The engine is powerful and it is a real machine. I enjoyed mine, but sold it to a friend and downsized. My property is wooded and on a steep hillside and a larger machine actually was slower than a smaller one on this terrain. If I had a more clear parcel of land, I would likely still own my 4520. I cannot see the reason to go into a 4720 unless one just wants to have one.
    John M
  9. #9
    Join Date
    Jan 2010
    Posts
    1,790
    Mostly East Central Oklahoma
    JD cut
    I've had a 4520 w/ CX loader and e-hydro for a couple of years now, problem free, and have found it very good to work with. Just yesterday my daughter wanted to move some dirt (never driven a tractor), so I turned her loose on it. Took three hours to get it back she was having so much fun. She even figured out how to level the dirt on her own.
    I use ear protection when operating it, but noise levels have been a problem on all tractors as far as I know.
  10. #10
    Join Date
    Feb 2009
    Posts
    935
    NC
    Quote Originally Posted by Cidertom View Post
    I love it.
    We're considering a 4720 could go into more detail on this issue? Are saying
    it's a Cat. 1 tractor with too much power for Cat. 1 implements?
    Thanks
    '11 John Deere 5065M /cab
    '10 Kubota L3940 w/FEL
    '09 JD X720
    '91 CaseIH 5140 Maxxum w/cab
    '78 IH 686 w/M&W Turbo 106 PTO hp w/canopy
Similar Threads
  1. thoughts on radiant barrier in attic
    By thatguy in forum Rural Living
    Last Post: 01-22-2010, 08:42 AM
  2. Price Check New 4520 Pricing
    By ejb17 in forum John Deere Buying/Pricing
    Last Post: 07-31-2009, 10:20 AM
  3. Opinions or thoughts on Toro TimeCutter ZX
    By 7mmrum in forum Toro / Wheel Horse
    Last Post: 11-22-2006, 10:41 AM
  4. Opinions wanted! 7' Backblades
    By couchsachraga in forum Attachments
    Last Post: 02-14-2006, 09:27 PM
  5. Straw Bale Building Thoughts & Opinions...
    By hobbyfarm in forum Projects
    Last Post: 09-06-2005, 12:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
