Results 1 to 4 of 4
  1. #1
    New Member Snowcatter's Avatar
    Join Date
    Mar 2010
    Posts
    8
    North Idaho
    JD 3720
    Default 48 & 448 Mounting Brackets
    I have a new 3720 with a 48 backhoe, and I would like to upgrade it to the newer model 448. My question is if the 448 uses the same mounting bracket as the 48? Or do I need to buy a new bracket as well? I have already purchased a new 448 assuming it would bolt right up, but I have not seen one up close to tell if it mounts the same . . . the salesman said it would, but I am not so sure
  2. #2
    Join Date
    Nov 2009
    Posts
    106
    Linn, MO.
    John Deere 4520
    Default Re: 48 & 448 Mounting Brackets
    I would try it before I bought the new brackets. I mounted my 448 on my New 4520 with cab that they said would not work. The mounting brackets that go on the new tractor where different from the open station 4520 that I had. I was able to modify the open station brackets to fit with a little torching and welding. Not much trouble really. You do not want to buy new brackets. Just for the big weldement plates they are $900 a piece. $1800 total. For that you could do alot of modifing. I don't know much about the 48 hoe but if it looks the same I bet it will mount right up. Good luck.
  3. #3
    Join Date
    Jul 2008
    Posts
    1,019
    Winterstown, PA
    JD 4200 & X475
    I'm thinking if a salesman suggested a route which didn't include a sale and related commission, they probably aren't lying about it.
    JD 4200 w/ 420 Loader, 8B Backhoe, 59" Snow Blower
    JD X475 w/ 54C Deck & 3-Bag Power Flow
    Looking for an engine out of a JD 4300/4310/4400/4410. Send a PM if you have one (or a parts tractor).
  4. #4
    Join Date
    Mar 2010
    Posts
    8
    North Idaho
    JD 3720
    Just FYI . . . The 48 and 448 use a completely different mounting bracket, not even close! So I have to buy new brackets Anyone looking for a slightly used mounting bracket for a 48 backhoe to 3720 & 4000 series tractors?
Similar Threads
  1. Backhoe JD 448 backhoe allignment
    By lesko200 in forum Attachments
    Last Post: 01-11-2010, 03:31 PM
  2. Need HELP MMM mounting question
    By hazmat in forum New Holland Owning/Operating
    Last Post: 08-05-2002, 08:24 AM
  3. Mounting Damage????
    By Kubota-monkey in forum Kubota Owning/Operating
    Last Post: 08-14-2001, 09:56 PM
  4. P/U Dumpbed conversion
    By scruffy in forum Rural Living
    Last Post: 08-08-2001, 06:03 AM
  5. Mounting Tiltmeters
    By Harv in forum Safety
    Last Post: 11-24-2000, 09:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
