Results 1 to 5 of 5
  1. #1
    Platinum Member prosperity's Avatar
    Join Date
    Aug 2000
    Posts
    690
    North Central Pennsylvania
    JD 2520
    Default 62D lock-up kit
    I just did the initial installation of the 62D on my 2520 (new 62D - old 2520).
    All went fine, but I noticed that with the deck off, and dropping the 3PH, the deck linkage actually will drag on the ground.
    Did some research, and found the lock-up kit - but for $150, I would rather fabricate my own.
    Does anyone have a good photo of the Deere lock-up kit so I can use that to make a material list?
    Or has anyone else done this themselves?
  2. #2
    Platinum Member glc24's Avatar
    Join Date
    Dec 2009
    Posts
    896
    Southwestern, Pa.
    Default Re: 62D lock-up kit
    Hello prosperity,
    I also was going to fab a way to keep the linkage up,but when I realized removing the four pins removed everything,that's what I decided to do.
    I may decide to figure some sort of bracket this summer before I would have to remove it again for winter. I'm betting it's alot easier to take it off than to put it back on. I'll find that out shortly.
    Greg
    2009 2520
    FEL/61" HD bucket/replaceable cutting edge
    62D2 MMM
    IMatch Quick Hitch
    Homemade 3PT Receiver
    Homemade Ballast Box
    Woods GB65 Box Blade
    A "REAL" snow blade --- JD 380A
    90% Restored 1987 JD 316
    MY BALLAST BOX:
    http://www.tractorbynet.com/forums/b...box-build.html
    MY SE SEAT 2520 MOD:
    http://www.tractorbynet.com/forums/j...my-2520-a.html
  3. #3
    Veteran Member Runner's Avatar
    Join Date
    May 2007
    Posts
    1,682
    Missouri
    John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
    Don't have any pictures handy, but here is the parts diagram from the JD web site. The top triangular-shaped piece bolts to the fender bracket. Parts #5 and 6 are a turnbuckle that is welded to the chain which attaches to the three-point arms.
    Attached Images Attached Images
    Runner
  4. #4
    Join Date
    Dec 2009
    Posts
    896
    Southwestern, Pa.
    Hmm,that looks easy enough to make.
    One question though,why the need for adjustability with the turnbuckle,and not a solid bar? Am I missing something?
    Greg
    2009 2520
    62D2 MMM
    IMatch Quick Hitch
    MY BALLAST BOX:
  5. #5
    Join Date
    Aug 2000
    Posts
    690
    JD 2520
    Thanks for the diagram Runner - that is even better than a photo!
    It looks like a bracket needs to be installed (#3 in the diagram) which would make more reason that the kit is so expensive.
    I think the adjustability with the turn shackles isn't necessary either, but this kit might be made for multiple models, so the reason for the adjusters.
    Hopefully I can fab something up without their bracket - once I get time to get going on this I will update.
Similar Threads
  1. Latch-up kit for a 62D MMM ?
    By scottrh in forum John Deere Owning/Operating
    Last Post: 05-23-2012, 11:06 PM
  2. insttalling hydraulic pump on 1920
    By jab-law in forum New Holland Owning/Operating
    Last Post: 09-01-2009, 06:48 PM
  3. Larry's axle kit with 62D question
    By 2Malamutes in forum John Deere Owning/Operating
    Last Post: 11-04-2008, 08:00 PM
  4. Getty Up Mule Speed Kit Review
    By Matt_Meiser in forum ATVs & Utility Vehicles
    Last Post: 03-09-2007, 06:44 PM
  5. What is included in the Gator deluxe cab?
    By gordon21 in forum John Deere Owning/Operating
    Last Post: 01-30-2007, 01:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
