Results 1 to 3 of 3
04-10-2010, 11:12 AM #1Silver Member
- Join Date
- Apr 2005
- Posts
- 112
- Location
- Minn
- Tractor
- JD 4110
4110 water pump rebuild--possible?
Well, my water pump has started to seep fluid from the weep holes; bad seal. Can see the pump is designed with what appears to be a removable backing plate. Has anyone every rebuilt one of these? If so, where did you find the replacement seal?
Also, maintence manual shows an O-ring in addition to a backing plate gasket. Anyone that had their's apart know if there is still one in there? Dealer thought not. Thks
04-10-2010, 12:19 PM #2
Re: 4110 water pump rebuild--possible?
I'm not familiar with your pump but there may be more than the seal needs replacing?
Bearings?? Shaft??
Egon
50 years behind the times
Livin in a
Worn out skin bag filled with rattlin bones
04-10-2010, 01:06 PM #3Platinum Member
- Join Date
- Jun 2009
- Posts
- 679
- Location
- wyoming
IMO, if you can not replace the impeller as well then is probably not worth rebuilding. You can try to match up parts with a Yanmar dealer but they will probably not be able to look up parts based on s/n as it will not show any info in their system due to an mfg agreement with deere (typically). $250 for a pump IS steep I think but not too bad. Good Luck
Similar Threads
An Old Goat Ranch in Texas
By terry.dinerman in forum ProjectsReplies: 482Last Post: 04-30-2013, 05:41 AM -
Using a generator to power a water well pump
By TheGoose in forum Rural LivingReplies: 77Last Post: 02-21-2012, 02:19 PM -
PTO WATER PUMP
By tc35dforme in forum AttachmentsReplies: 12Last Post: 06-06-2009, 09:56 PM -
Running Water Lines
By Alan L. in forum Rural LivingReplies: 53Last Post: 08-12-2005, 12:39 AM -
Water Pump - electric or PTO
By Pooh_Bear in forum AttachmentsReplies: 8Last Post: 06-12-2005, 05:31 PM
