Results 1 to 3 of 3
  1. #1
    Join Date
    Dec 2001
    Posts
    93
    Grundy County, IL
    JD 755
    Default Parking Brake adjustable? 755/855/955
    Is the parking brake linkage adjustable on the 55 series? I had the tunnel top cover off and was checking it out. I'd like to adjust the position of the piece that blocks the go pedals inside the tunnel. To do that, there would have to be a way of adjusting the linkage, and it is hidden. I won't bother uncovering it if it isn't adjustable. Possibly the adjustment is simply to bend the linkage rod. Or maybe I need to loosen the tractor brakes somewhat, so that I can pull the parking brake lever up farther. Right now it doesn't pull up very far, and consequently the block thing isn't quite down where it should be when the brake is set.
  2. #2
    Platinum Member JD755's Avatar
    Join Date
    Aug 2009
    Posts
    917
    Kansas
    John Deere 755 purchased new in 1993
    Default Re: Parking Brake adjustable? 755/855/955
    I have never had need to adjust any of that, but here is what the manual shows. The last drawing may be of most use regarding the linkage for the park brake set.
    Attached Thumbnails Attached Thumbnails Parking Brake adjustable? 755/855/955-755-brake1-jpg   Parking Brake adjustable? 755/855/955-755-brake2-jpg   Parking Brake adjustable? 755/855/955-755-brake3-jpg   Parking Brake adjustable? 755/855/955-755-brake4-jpg
    JD 755, 70 Loader, 60 inch MMM, Landpride rear blade, Modern box blade, Wallace subsoiler
  3. #3
    Join Date
    Dec 2001
    Posts
    93
    Grundy County, IL
    JD 755
    Thank you very much! I've saved your jpegs to my PC and will check them out.
Similar Threads
  1. Parking Brake Won't Stay Set
    By jnelson in forum Cub Cadet Tractors
    Last Post: 04-11-2010, 09:41 PM
  2. Parking brake light or buzzer
    By Dennis5 in forum Kubota Owning/Operating
    Last Post: 02-11-2010, 03:32 PM
  3. Parking Brake Light
    By the fox 1940 in forum Kioti Owning/Operating
    Last Post: 10-03-2009, 07:33 PM
  4. Oops left parking brake on 4115
    By Newtogreen in forum John Deere Owning/Operating
    Last Post: 06-11-2007, 09:54 AM
  5. 2910 Broken Parking Brake
    By glennmac in forum Kubota Owning/Operating
    Last Post: 10-30-2000, 10:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
