Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Jun 2009
    Posts
    3
    John Deere 2520
    Default 2520 Mechanical lift kit pins are shearing.
    I have a 2520 with the mechanical lift for the 62D mower.
    The bar/pin that separates the lift arms keeps shearing the cotter pins.
    This has happened three times since it was new, July 2009.
    The bar/pin is item #20 in the diagram.
    Is this normal?
    Attached Thumbnails Attached Thumbnails 2520 Mechanical lift kit pins are shearing.-mp37981________un03may06-gif
  2. #2
    Elite Member Rob-D's Avatar
    Join Date
    Oct 2006
    Posts
    3,078
    Catskills
    John Deere 3320
    Default Re: 2520 Mechanical lift kit pins are shearing.
    Quote Originally Posted by 85Bears View Post
    Is this normal?
    Hi Bears,
    Check the deck with it all the way up and see if it's hitting anything. Do you have a hydro lift kit?
    Rob
    Rob
  3. #3
    Veteran Member Runner's Avatar
    Join Date
    May 2007
    Posts
    1,682
    Missouri
    John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
    I woudn't think there would normally be that much side-to-side pressure on this connection. You might try replacing the cotter pins with lynch pins, if you can find one that fits the hole.
    I haven't had the problem on mine (yet).
    Runner
  4. #4
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    There was one member that had problems with this issue...stared a LONG thread about the 2520 being junk or something like that...I will remember his name later
    But IIRC it turned out to be a setup problem...like the anti-scalp wheels where supporting the deck weight all the time and not allowing the deck to "float" or something like that-I will remember soon
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  5. #5
    New Member
    Join Date
    Dec 2009
    Posts
    6
    The problem is the deck is lifting too high. Incorrect set up by dealer. Raise the deck all the way up and you will see that it hits the frame of the tractor.
    I know this from experience. Easy adjustment and it will stop your problems.
  6. #6
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    Here are the ones I was thinking of, from user 47chevy:
    http://www.tractorbynet.com/forums/j...d-falling.html
    http://www.tractorbynet.com/forums/j...ml#post1729999
    Basically, he was not putting the hydraulic lift circuit into float, so the deck could not move up and down to follow the terrain.
    KennyD
    www.boltonhooks.com
  7. #7
    Join Date
    Aug 2008
    Posts
    87
    john deere 2520
    Yes that was me having the issues with the deck pins. Since the deck was put in the float position I have not had any issues with the deck falling out . My deck actually moves up and down and flops around now
    I was using the mower per the owners manual, lockout the scv while mowing. That prevented me from putting the scv into the float position.
    The deck wheels are adjusted per the manual and dealership, that is 1" of clearance on level ground. It turns out that the deck and pins carried all of the weight of the tractor anytime I went over a low spot.
    Hope this helps you with your problems. It does get very frustrating when you pay good money for a machine that fall apart.
  8. #8
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,930
    Southern Wisconsin, USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Is this normal?
    For sure it wouldn't be normal. And for sure the dealer should have recognized such when the deck was set up, and also when you went back to discuss the problem three times.
    Takes some serious pressure to shear cotter pins, so they should have had a clue that the deck was not set up right.
    Glad you have now found the answer.
Similar Threads
  1. 2520 lift
    By duster74 in forum John Deere Owning/Operating
    Last Post: 04-18-2008, 11:35 PM
  2. 2520 Mechanical Diverter for independent lift
    By Holiday in forum John Deere Owning/Operating
    Last Post: 12-27-2007, 08:52 PM
  3. 4500 remote hydraulics
    By T King in forum New Holland Owning/Operating
    Last Post: 11-03-2007, 12:44 AM
  4. Cat 0 lift arm pins needed
    By lpp in forum Kubota Owning/Operating
    Last Post: 06-09-2005, 10:15 PM
  5. lift arm pins
    By tonyw in forum Yanmar
    Last Post: 10-10-2003, 09:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
